takahashi
07-19-2009, 09:38 PM
I decide that I don't use the 8 that much now and I put the RX-8 as a test mule for cut and polish - major time. If I stuff it up - at least I won't cry over it :evil_laug :smoker: I don't want to use Zaino either, coz it is on the expansive side and I want something that everyone can do.
I kept using the same products. I have Meguire detail spray with clay bars. Autoglym hard deep gloss wax, the lovely resin polish which I like very very much, the new meguire scratch X 2.0 *(twice as expensive as the original but 2x good - $20), and the bumper care gel which I like becoz I can't be stuffed masking tape all the plastics. It removes extra wax very well.
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02125.jpg
I have the good old orbitor going at low rev - which is good for applying wax at the end but I need something to cut the scratches so....
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02126.jpg
I brought this long thing below - an orbitor from Supercheap auto (I can only find it at Preston shop). It is called Rockwell shopseries (made in China) ... it's a 5" orbitor going from 500rpm to 3000rpm (1-6 setting) and has a velcor backing you can attach the wool pad on. However, I replaced it a foam pad instead (I brought a very nice foam pad from autobarn for $26 made by K&H - local and australian made). The orbitor from Rockwell is about $72 - on sale at the time.
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02103.jpg
It looked like a swirl city before I started. I started by using the clay bar to get rid of the big residual first. It should feel like smooth after clay bar.
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02101.jpg
This is after 1-2 applications of scratch 2.0X with the faster orbitor setting at 2000rpm-2500rpm.
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02102.jpg
I need 3-4 applications to bring back most swirls. Now it just leave the thousands of stone clips I collected on the track days.
Final results: There is still some ripple strip effect under strong sun. I don't know how to get rid of it (EDIT: On retrospect I may have used too much wax for it. I will cut down on them for next time)
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02120.jpg
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02119.jpg
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02121.jpg
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02122.jpg
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02123.jpg
http://i97.photobucket.com/albums/l230/taka_rx8/polishmy8/DSC02124.jpg
The car is still very easy to collect swirls afterwards. There is a product out there to firm the wax up and resist minor swirls. May be I will use it next time.
