Atf?
Old Jul 17, 2009 | 12:43 PM
Geared4me's Avatar
Atf?
I have searched and only found threads relating to the manual trans. fluid. Has anyone used any other atf like Royal Purple or Redline? I was considering the RP for my tranny and rear diff, what do you use?
Old Jul 17, 2009 | 04:09 PM
Easy_E1's Avatar
I'm going to be installing the Enoes ATF in the near future. I'll give my impresions when this is done.
I have used and been a fan of Redline in prior AT vehicles.
Old Jul 17, 2009 | 04:10 PM
Geared4me's Avatar
Charles, thanks for your response,I thought that might be the case. I can get the Royal Purple at my local Pep Boys so I think I will try it and see how it goes. If I have any problems I will just drain it,atf is easy enough to get.
Hey Easy, was the Redline a noticeable improvement? Maybe I shouldn't just go with the easiest to get. I would be very interested in what you think of the Eneos ATF,where do you get it from? Thanks
Old Jul 17, 2009 | 04:12 PM
Easy_E1's Avatar
If your gong to change it I would suggest using the Flush type of trans fluid change. It costs a bit more than just draining it but it will replace 99% of the fluid.
Old Jul 19, 2009 | 12:30 PM
mdw1000's Avatar
I'll snap his neck.
I'm using Amsoil. Seems to work well. Track temps don't exceed around 200 degrees F.
ASH8
79
Aug 12, 2024 07:06 PM
airlive
Jun 28, 2020 07:46 AM
PitchBlaC
Far East/Asia
Sep 5, 2006 04:48 AM
gfoo
Far East/Asia
Mar 11, 2006 08:13 PM
