Mazdatrix Wires
Old Jul 13, 2009 | 06:24 PM
Dkati's Avatar
Question Mazdatrix Wires
Picked up some Mazdatrix wires for my plulg change.
They showed up, but they look way different on the coil connection side than the stock wires on the car.
The stock ones have a little spring inside, and are open and round. There is no metal that extends past the boot.
The mazdatrix wires have no spring, and what looks like a round "claw". It sticks out past the boot. If these wires are supposed to fit, my assumption is that the metal claw would be pushed INSIDE of the coil. Seems like this will bend the "claw" ...
.. so, not wanting to break anything, this makes no sense.
Anyone install mazdatrix wires before?
http://www.mazdatrix.com/8ignition.htm
Old Jul 13, 2009 | 06:28 PM
dozer's Avatar
on his 3rd rx8
i think your stock wire broke...i assume it looked like atillas when we took his out...your fine. That metal peice sticking out is fine, make sure theres nothing stuck in the coil from the stock wire
Old Jul 13, 2009 | 07:03 PM
Dkati's Avatar
I got to looking, and nothing looked broken on the wire.
I stared at a picture of the coil, and determined I must be a moron.
Apparently, the coil has a "top piece" that got pulled off with the wire. No idea if this is supposed to happen or not.
I pulled that "top piece" from the end of the plug and pushed it back on the coil until it clicked. Now, the wire looks like a proper spark plug wire... changing should be trivial now.
Took her out for a drive just to make sure I hadn't jacked anything up... all was ok.. so hopefully I didn't break anything
Chalk one up to the n00b.
Old Jul 14, 2009 | 12:47 PM
They work fine I had them.
tjohnmeyer
Sep 28, 2017 05:03 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
