View Full Version : QLDers if you want some track time before the Nats
mdr
07-13-2009, 02:15 AM
Lakeside sprints this Sunday the 19th.
http://www.qldraceways.com.au/Administration/pdf/2009EntryForms/LakesideStreetSprintsEntryForm2009.pdf
skc
07-13-2009, 03:12 AM
I am undecided at this stage. I will definitely be attending the event on 2nd August as I have been participating in the open sprints regularly and currently in the top three spot in my category.
The last time I attended I got a time of 63,7 seconds. I am getting Tein coilovers and project Mu brakes fitted tomorrow and my target is to get 61 seconds.
skc
mdr
07-13-2009, 08:08 AM
skc
Is that 63 secs at Lakeside?
That is fast. Did the redo of the track make it that much better or are you just getting that good at it?
skc
07-13-2009, 09:24 PM
That time was at Lakeside.
The track has been upgraded since the last nats. The changes are documented on the QR website. The main change is the resealing and widening of the straight.
skc
Revolver
07-13-2009, 11:44 PM
Are the noise nazi's still in residence? - I still think the guys running the track that day for the Nationals were a pack of dickheads...not being able to push hard greatly diminished my enjoyment of that track... :icon_tdow
Congrats on your times though. Sounds like you're having a good time with it all...
skc
07-14-2009, 06:44 PM
They are nowhere near as stringent now. They are now measuring from a greater distance. I have seen full race cars with next to no exhaust get around. The really loud ones get sent home.
I am happy with my track times and it seems to be getting better each time. The new coil overs should make a difference the next time I go around.
skc
skc
07-18-2009, 12:08 AM
I am booked in for this event . I feel I need to get some practice with my new coilover. A lot of tinkering required before I feel comfortable driving at the limits.
I will be going easy as I still have to wear in the new brakes, So far I have done 250 kilometers with them on. The installer said I have to do around 1000 before I can really punish them. I hope I don't get too carried away.
skc
ORX-800
07-18-2009, 06:47 AM
Good luck tomorrow skc! :wiggle:
Cheers,
Danny
skc
07-19-2009, 03:21 AM
Had an interesting day at the track today. Came off the track twice, lucky that there was a grassy run off area. The first time was most likely as a result of too much speed into the corner and as the track temp went up my tire pressure went up with it. The higher pressure led to less grip. The second off was deliberate as a open wheeler car had just spun on the same corner and was sitting across the track. I noticed this just meters before him and the only way to avoid collision was to go off track. If I had hit him at 100kmph side on with the driver on my side it would have been a disaster.
Anyway I managed to better my lap time and got it down a few tenths to 63.3.
The new coil overs does offer less roll. The dampers where set at level 1 at the rear and level 3 at the front. This seems to give a very neutral handling. A bit more tweaking required.
I will have to get my clutch looked at as It seems to crunch going into 4th gear after the 2nd lap. This did not help my lap times much.
skc
Jambos
07-19-2009, 04:18 AM
Salesh
I tried to get around to Lakeside today to see you but yard work kept me busy all day, maybe next time.
Laurence
skc
07-20-2009, 03:00 AM
Hi Laurence
The next track day will be 2nd August. I will most likely be there as well.
skc
Jambos
07-20-2009, 07:01 AM
Salesh
I am going OS (Italy) for four weeks on Friday, won't get back until 24th August.
Laurence
mdr
07-20-2009, 11:18 PM
I planned to make it out for the day but a friend called and wanted to meet me and wife at the casino for dinner and I ended up playing blackjack till 5 am Sat night.
