Blown engine, rebuildable?
Old Jul 9, 2009 | 12:10 AM
Twiek's Avatar
Question Blown engine, rebuildable?
Well... seems I blew the engine in my '04 on the highway tonight...
The CEL flashed as I was merging onto the interstate, and noticed a slight power loss. I backed off a bit figuring it might have been a misfire and initially nothing seemed out of place, but as soon as I gave it a little gas again, it must have blown the first rotor, as it produced a large oil cloud and grinding noises, combined with significant power loss, and then the second in short order, where it completely cut out (revs dropped to 0 with the clutch in, no matter if I gave it gas or not, and wouldn't relight after popping the clutch). The oil light did come on earlier that same trip, but it never lost oil pressure until the revs dropped.
I turned the starter over and it sounds like it has zero compression. It struggles, but there's no periodic lug at all. Could it have blown all 6 tips in such a short time? or is it something more sinister? Of course I don't know what the inside looks like yet, but does this sort of thing usually tear up the housings and rotors? I might attempt a rebuild, but I'm not sure it wouldn't be cheaper and easier to find a replacement if I have to replace pretty much everything anyway...
The chassis has 118k (so no warranty), but there's only ~21k on the engine. I broke it in "properly" (first oil change @ 1500 mi, low revs for ~4000 miles) and it was running like a top 'till it blew.
Old Jul 9, 2009 | 12:38 AM
wow,
this is a hard one. depends on who replaced and what the old motor was replaced with.
if if was mazda you have a fighting chance. if not, well you can have the motor rebuilt.
but you need to find someone that does rotary rebuilds for a living. they are around here..
Old Jul 9, 2009 | 08:07 AM
Lets just say your engine really "blown" with apex falling apart.
Due to the Side exhaust port design, most likely it will trash everything in there with it.
yes its "probably" rebuild-able, but prepare to buy a new side housing, rotor housing, int housing, Rotor itself, and all seals within that rotor chamber.
I think that explains it all. you pretty much fuxked yourself up. and you believe your oil pressure gauge on the dash?
Old Jul 9, 2009 | 08:22 AM
Im_DANomite's Avatar
I love GOOOLD
true that, don't believe in any of the stock gauges. the other day my DEFI gauge spiked up to about 230 degrees, but the stock coolant temp read perfectly fine. i had a coolant leak from the coolant line that goes to the throttle body.
Old Jul 9, 2009 | 10:26 AM
Mazmart's Avatar
Rotary engines don't just 'blow rotors' or apex seals. My first thought is an oil related failure but who knows. Where did the 21k engine come from? Is it a Mazda reman? Is this car turbocharged?
Paul.
Old Jul 9, 2009 | 11:03 AM
I disagree. Having built a few engines which had blown apexes, I mostly saw a grooved housing but the side plates are rarely damaged. I wouldn't say I have done enough engines yet for my info to be empirical so take it only as anecdotal.
I will say this with confidence, though; if one decides to have their engine built, make sure to have your side seals custom gapped as the OEM clearances are terrible.
Just saying there is a possibility. Cuz in the older Rotary with P-port. the failed seal(s) will be push outa the chamber by the rotor.
13B-MSP ... Side port ... thats just not possible
the failed part will just keep "rolllllin" inside ... rolling ... and rolling ...
Now Back to OP's topic, I have a feeling his motor failed cuz he got no oil in there ... he said it himself, his oil light came on ... I know its not always accurate but ... there is a chance that he got a leak somewhere in the first place but he just keep driving it ... Kaboooooom !
Old Jul 9, 2009 | 11:19 AM
notorque's Avatar
I bid thee farewell
car-parts.com has cheap engines on there. most rx8 MT engines are around 3g on there with less than 30k miles. orrrrr you could just rebuild, the million dollar man route.
http://www.mazdatrix.com/getprice.asp?partnum=10008
Old Jul 9, 2009 | 11:30 AM
I would rather get a Rebuild motor from some places like Mazmart than a Used motor with 30 K on it for 3 grand.
Old Jul 9, 2009 | 01:00 PM
04RX8man's Avatar
Rotary Powered Countryboy
Well your first mistake was driving it with the oil light on...when that's on (like said many times before on this forum) it's too late....the pressure gauge is at it's normal position as long as ther is any kind of positive pressure...0 pressure then it drops.....
should've check the oil often
Old Jul 9, 2009 | 01:28 PM
I8U's Avatar
I8U
^Man I missed that when I first read the OPs post, oil light=stop and check oil level NOW. If the OP ran the motor out of oil as I suspect, I say start looking for a fresh rebuilt motor and get rid of the ruined one.
Old Jul 9, 2009 | 02:57 PM
Twiek's Avatar
It's possible the pickup went dry, but it doesn't seem like it ran out of oil... It left at least a quart on the road, and there's still some left in the pan (I'll check the level when I get home tonight)
I figured that was a possibility, which is why I posted about the pressure gauge... But if the gauge won't show a dropout bad enough to nuke the engine, it seems like it's a fairly pointless accessory.
Paul.
It's a factory reman, installed by the Paul Miller dealership in Lexington under warranty. Bone stock.
That's exactly what I'm afraid happened
The light has come on a couple times before I caught it low, and every time it was about a quart low. I do check the oil fairly often (probably on the order of once a week or ~550 miles), and the last check it wasn't low. If it was an oil starvation problem, something else precipitated it... although I will admit I didn't stop and check the level. I didn't have a spare with me at the time (I know, I know), and figured I could make it 15 more miles home... guess not.
Thanks for the advice guys. Looks like I'm now in the market for a rebuilt engine... :sigh:
Old Jul 9, 2009 | 04:08 PM
Mazmart's Avatar
Hmmm, I wonder who may have reman in stock presently?
Paul
Old Jul 9, 2009 | 04:56 PM
04RX8man's Avatar
OOOO I might know!
ouimetnick
25
Sep 14, 2023 01:44 PM
vapor2
Nov 3, 2020 03:38 PM
rotorocks
47
May 11, 2016 03:23 PM
uZu
Dec 30, 2015 12:35 PM
MolecularConcept
Aug 9, 2015 04:46 AM
