Idle problems...
Old Jul 8, 2009 | 03:31 PM
RX8racing05's Avatar
10K Redline
Idle problems...
I just installed the K&N typhoon intake and now everything is hooked back up the idle doesn't sound the same as it did. Seems to fluctuate between 500 and 1000 RPM's. Is this because I had the battery disconnected and now the ECU is just resetting itself? Or is this something else minor?
Old Jul 8, 2009 | 03:51 PM
invasion08's Avatar
If everything is hooked up correctly then yes it is the ecu resetting. A few drive cycles and it will be good.
Old Jul 9, 2009 | 08:57 PM
And if it doesn't go away its due to the intake or the install.
You shud be fine after a few drives.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
Quiggs321
Sep 30, 2015 05:34 PM
