View Full Version : Has anyone in Sydney done this simple DIY mod?
matt13b
07-08-2009, 08:27 AM
VFAD (Variable Fresh Air Duct) removal or alternatively capping the vacuum hose to keep it open all the time?
Here is the DIY thread- http://www.rx8club.com/showthread.php?t=148881
I like the part halfway through where people work out you just need to cap a hose off to keep the VFAD open the whole time, therefore feeding more fresh air to the engine. It seems like a mod that has no drawbacks. Do you guys agree or am I missing something?
2SeeKU
07-08-2009, 09:39 AM
I can't see any draw backs. More air = more power. Especially since the 2003's (not sure if it's auto only) don't have a vfad...
Edit: Plus, the ms/aem intakes require you to remove it (plus plug the vacum line).
matt13b
07-09-2009, 02:36 AM
I agree and was hoping there was someone in Sydney I could have help me do it. I mean just point to the right hose to cap? I can't see any drawbacks. It seems win-win. It is just to keep the car quiet at low speed by starving the engine of air..
DrewMan
07-09-2009, 06:30 AM
I just got rid of it altogether
Odula Ram air intake
http://www.odula.com/img/img_026.gif
Revolver
07-09-2009, 08:16 PM
To me this falls into the "more noise for doubtful benefit" category.
People have frigged around with intakes since the Renesis was released and I've yet to see any evidence of appreciable power gains. More air doesn't necessarily equal more power if the intake has already been optimised.
matt13b
07-09-2009, 08:37 PM
Well it started on Sunday when a mate and I put in a second oil cooler. When we took the bumper off I was shocked to see where the factory airbox is fed from. It points sideways behind the bumper which to me seems that the air it draws would be warm engine air at best. So I thought that I may get the Odula duct to feed the box with better air at a better angle. While researching the Odula duct found people who were removing or disabling the VFAD.
I've read the pros and cons of it on a long thread and it seems that it is something that starves the engine of air in order to keep it quieter at low speeds rather than something that is there to optimise the air flow to the airbox.
Revolver
07-09-2009, 10:07 PM
Yes, I've read the long discussions too - and my point stands. Lots of conjecture, bugger all hard evidence...but if you want to play, go for it.
ASH8
07-09-2009, 10:14 PM
Dave is right on here, Removal of the VFAD contributes to more induction noise, and I also have not seen ANY so called HP gains or any performance gains at all.
When will guys get it through their heads that Mazda have done EVERYTHING they possibly could to get the Max power out of the Renny in NA form.:SHOCKED:
Turbo IMO is the only way to get more HP and Torque.
Revolver
07-10-2009, 12:41 AM
Or supercharging, agreed.
I fitted a catback because the stock car sounds like a vacuum cleaner on speed and Hymee's design dissipates boot heat better but I've ignored the intake side of things on the basis that Mazda thoroughly developed the breathing of the Renesis and I don't need induction noise added to my exhaust noise. Until someone posts some reliable before and after dyno information, I'm happy to stick to that view.
But, as posted earlier, people seem to like to play with intakes as much as they like fitting after market exhausts, so who am I to spoil their fun...
rotarenvy
07-10-2009, 04:19 AM
I'm running N/A without the v-fad at the moment. any benefit is barely noticeable. it is noisier but does sound kind of cool.
I think an odula or revi duct for cooler air would be nice and would make a noticeable difference.
2SeeKU
07-10-2009, 05:19 AM
Hmm, l'm not sure about power gain (I went from bone stock to an AEM). I can tell you however, an AEM adds nowhere near the same amount of power as an over the rad cai on a V8 commodore...
takahashi
07-10-2009, 08:10 AM
matt:
http://www.rx8club.com/showthread.php?t=58857&highlight=odula+intake
matt13b
07-10-2009, 10:30 AM
Thanks Taka. That was actually the thread I was referring to that got me interested in the VFAD. I think I will order an Odula duct..
Revolver
07-12-2009, 07:24 PM
Then do us all a favour Matt and organise to dyno it before and after installation (on the same day using the same dyno if poss).
Would be good to see some hard numbers instead of butt impressions...
matt13b
07-13-2009, 03:35 AM
You guys have successfully talked me out of it, sorry! It was this link from Andrew that changed my mind finally- http://en.wikipedia.org/wiki/Variable_l ... e_manifold
takahashi
07-13-2009, 04:17 AM
That will not give hard numbers, since there is no fan in the dyno world will generate the air you get travelling 100kmh.
Try a Gtech, Dynolicious or if you have cash - VBox Racelogic. ie on road dyno.
Revolver
07-13-2009, 07:10 PM
Well just think Matt, with the money you've saved you can pick up a spare set of track rims... :rollingla:rollingla:rollingla
auzoom
07-13-2009, 07:32 PM
Matt, I still think there is benefit from extending the existing intake runs to pull cool air. I did it on my old RMagic front end and it was much snappier on the throttle.
matt13b
07-14-2009, 02:35 AM
So you think something like the Odula duct would still be beneficial? There has to be a better way to feed the air than that tube that sucks warm air from behind the bumper surely!
auzoom
07-14-2009, 07:45 AM
This is one way http://www.rx8club.com/attachment.php?attachmentid=93083&d=1169796196
matt13b
07-14-2009, 09:06 AM
Interesting but very expensive looking! I'm not big on body kits actually. I tend to stick to mods that do stuff rather than look good. I like the look of some kits but prefer to spend the money in other areas. I would have already ripped it off by now as well. It's hard enough getting in and out of driveways now without a kit!
auzoom
07-14-2009, 03:39 PM
Matt, we have debated looks v functionality already this week. The point wasn't to identify the body kit but the fact you can quite simply open up that low rpm runner to fresh air. This is one way, I have seen it done on an OEM front end and I can imagine you could do it quite ... stealthily.
Cheers
Andrew
Revolver
07-14-2009, 07:20 PM
I've seen that before too. Before you start cutting holes in things I'd think long and hard about functionality v resale. I think most punters would run a mile from a car with that kind of mod...
auzoom
07-14-2009, 09:02 PM
OK ... I will clarify again...I am not saying anyone should or needs to cut into anything. Having said that, how do you think the VFAD removed with a ruddy great snorkel is going to affect resale?
Matt is a creative guy, I am sure he can find a way to do it without cutting...I can think of a few.
Cheers
Andrew
Revolver
07-14-2009, 11:06 PM
Cheers
Andrew
I wasn't suggesting you were advising anything Andrew - merely offering my 2 cents. And I quite agree about the ruddy great snorkel, which is why I would leave the VFAD as is unless and until someone can demonstrate that it's worth removing.
And to clarify, I'm not trying to stymie anyone's creativity - just suggesting that as the benefits are hardly mind blowing (pardon the pun), Matt might like to think twice before spending time and money on it.
:grouphug:
2SeeKU
07-15-2009, 06:45 AM
How's this for stealthy:
http://www.leg-sport.com/cate/hi_991.jpg
http://carview-img02.bmcdn.jp/minkara/photo/000/001/531/888/1531888/p2.jpg
Even though l have an AEM fitted, agreed. The benefits are so marginal, they're barely worth any dollar spent on a CAI system. I just don't see any negatives to remove the vfad, especially since Mazdaspeed did with their setup.
matt13b
07-15-2009, 09:23 AM
That stealthy setup is awesome! Mazdaspeed removing the VFAD does give it's removal a lot more credit and points toward it being there purely to keep the car quiet. Still, I do think that if it did anything at all someone would have some dyno evidence by now..
