Question for MazdaSpeed Cold Air Intake owners
Old Jul 6, 2009 | 09:02 AM
BigMikeATL's Avatar
My recently purchased 05 Shinka has a MazdaSpeed CAI installed and I was wondering how often the air filter needs to be changed.
Is this one of those that can be cleaned and re-used?
If I do change it, what do you guys recommend?
Old Jul 6, 2009 | 09:19 AM
Grungepup's Avatar
Oilfield trash
I clean mine every 10k, its a dry filter so dont use the K&N oil.
I also clean the pipe itself every other oil change, this gives a chance to see if the screens have dislodged. It is also a good time to clean the MAF sensor.
Old Jul 6, 2009 | 07:40 PM
BigMikeATL's Avatar
Does the filter ever need to be replaced? If so, how often?
What do you use to clean the pipe?
Old Jul 6, 2009 | 08:01 PM
Jon316G's Avatar
Grasshopper
When I had the AEM intake (same design as the MS) I followed these instructions:
Old Jul 6, 2009 | 08:07 PM
J8635621's Avatar
Pew Pew Pew
Filter does not need replaced unless it becomes damaged afaik.
Old Jul 7, 2009 | 08:42 AM
Grungepup's Avatar
Oilfield trash
I use just a regular clean rag, make sure it is one that wont leave lint.
Old Jul 7, 2009 | 09:41 AM
You can use K&N's filter cleaner to clean it, spray the solution to the "INSIDE" of the filter, let it soak for maybe 10-15 minutes. Then rinse it with tap water from the INSIDE until you cant see any oily residue on the water.
then just let it dry, I usually leave it on my Home Air Filter, it dries them up nice and fast.
Old Jul 7, 2009 | 11:05 AM
laythor's Avatar
I zoom therefore I am.
I usually buy the cleaner from my dealer once a year. You need two large buckets from home depot and a couple hours of time. It's two bottles and you use both of them.
It involves taking off the front bumper but after you've done it once you can take off the front bumper in 10 minutes every other time.
The reason it takes a few hours is for drying time to the filter, I've been able to speed this up by putting my filter in my front load dryer sitting on the sweater rack and turning it on it's lowest heat setting. I would suggest doing this when the wife/girlfriend is not home to avoid any "@#&*^@#&" moments.
Old Jul 7, 2009 | 11:45 AM
BigMikeATL's Avatar
Thanks for the feedback. I'll try this some time this weekend. Taking the bumper off should be an adventure.
Old Jul 7, 2009 | 11:50 AM
Huey52's Avatar
Registered Zoom Zoomer
It's a bit of an adventure the first time you remove the bumper, but once you've done it thereafter you can do it in your sleep and rather quickly. Just mind the foglight connectors and of course first remove the side marker lights (corners). Good DIY's here.
https://www.rx8club.com/showthread.p...bumper+removal
btw: I thought you could reach the MS filter, albeit with some difficulty, w/o bumper removal?
Old Jul 7, 2009 | 03:39 PM
laythor's Avatar
you can reach the filter by unscrewing the undertray and reaching up from under the car. You would need to jack up the car, especially if it's lowered. Time to jack up car >/= taking off the front bumper. With the bumper off it also gives you a chance to inspect everything and clean out any leaves and junk that's back there.
SupraG
Sep 21, 2015 12:09 AM
Mr.Durden
Aug 12, 2015 02:21 PM
SupraG
Aug 3, 2015 10:03 PM
MrORAN6E
Jul 24, 2015 09:32 AM
AussieGray
Jul 16, 2015 03:58 AM
