Car wont start
Old Jul 5, 2009 | 01:38 AM
Jon316G's Avatar
Grasshopper
Time to charge the battery.
As long as the battery didn't go below ~5V, you can usually recharge it without problems.
Deflooding with the accelerator down cuts the fuel, but the next time you cranked it you need to have your foot off the pedal.
Hopefully you weren't just doing it continuously with the accelerator pedal down and hopefully you were cranking it no more than 10 sec.
Have you tried jump starting or push starting it?
Old Jul 5, 2009 | 04:14 AM
Spinning Sushi's Avatar
I <3 Sushi
That's symptoms of a bad battery. Bring it to AutoZone, or an autoparts store that have battery testing. I'm 99.9% sure that it's a bad battery.
Old Jul 5, 2009 | 10:21 AM
04RX8man's Avatar
Rotary Powered Countryboy
Diehard Grp. 35...and if it is flooded take the plugs out and fuel pump fuel crank to get all the excess gas out of the chambers reinstall plugs and fuse and shoud fire right up!
Old Jul 5, 2009 | 05:53 PM
Jon316G's Avatar
Grasshopper
Originally Posted by GeoffRX8
do rx8's really need group 35 batteries?
The group size identifies the battery dimensions.
35 is what our car uses.
Old Jul 5, 2009 | 07:48 PM
Jon316G's Avatar
Grasshopper
Chances are it will reset itself.
Disconnecting the battery for a few minutes will do this.
Old Jul 6, 2009 | 03:54 AM
Jon316G's Avatar
Grasshopper
It probably is flooded.
1st time I had a flood it took me a while to get it started.
I would crank it (10 sec intervals) until the lights would dim, then I charged the battery and tried again. Eventually I got it going.
This was before I learned other ways to deflood.
One method people like is push starting it.
Others like to remove the spark plugs, remove the fuel pump relay, and give it a few cranks to remove the gas.
I've started a few RX8s by squirting washer fluid into the maintenance ports.
So there are several methods that seem to work.
Search the various DIYs and pick a method.
marc2820
Jul 26, 2015 10:47 PM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bamaham
Jul 23, 2015 08:08 AM
Kangarhew
Jul 18, 2015 08:27 PM
