View Full Version : RX8 Wire Colors & Locations
tksnobords
06-28-2009, 04:51 AM
PLEASE TEST THE WIRE'S...OR BAD STUFF HAPPENS. DON'T ASSUME THE INFORMATION IS PERFECT. ITS NOT WORTH DAMAGING YOUR CAR.
TEST, TEST, TEST
If you have anything to add, email me at tksnobords@gmail.com and i will update the list.
12 Volt (+) 12ga. White/Red in driver’s door harness at driver’s kick panel or 12ga Orange just above kick panel
Ignition 1 18ga. Black/Yellow at driver’s kick panel (will be in same harness as door trigger)
Accessory 1 12ga. Green/Yellow (R.A.P.) in driver’s door harness at driver’s kick panel
Starter 18ga. White/Blue left of steering column in small White connector
Horn 18ga. Green/Orange (-) left of steering column in large White connector
Lights (+) 18ga. Red/Yellow left of steering column in large White connector
Lights (-) 18ga. Orange (flashes hazards) at flasher under left side of dash above trunk release button
Door 1 18ga. Black/Blue (-) at driver’s kick panel
Interior Lights Same as door trigger
Trunk/Hatch 18ga. Brown (-) at passenger’s kick panel
Hood Pin 18ga. Violet/White (-) (N.C. use relay) above driver’s kick panel in smaller group of wires that lead into main harness going through firewall
Trunk Release 18ga. Yellow (-) at trunk release button on bottom left side of dash
Lock (switch) 18ga. Lt. Green (-) @ 1000 ohm in driver’s door harness at driver’s kick panel
Unlock (switch) Same wire (-) @ 0 ohm
Disarm (key) 18ga. Green/Red (-) @ 0 ohm in driver’s door harness (extended pulse will unlock all doors)
Arm Input 14ga. Red/Blue (M) in driver’s door harness or at keyless entry module behind passenger’s kick panel
Disarm Input 1 14ga. Red/Black (M) at same
Disarm Input 2 14ga. Green (M) at passenger’s kick panel in door harness or at keyless entry module
tksnobords
06-28-2009, 04:31 PM
12v and Ignition Wires
Motomouse
06-28-2009, 04:36 PM
thanks for your replay !!
the 2nd and 3rd pics are showing the ignition wire black with yellow correct??
Thank you
tksnobords
06-28-2009, 04:41 PM
Yeah the Ignition is Black/Yellow
FarSide792
12-02-2009, 12:54 PM
What does R.A.P. mean? And this is only powered on with the ignition, correct?
tksnobords
12-06-2009, 03:08 PM
i am finding out what RAP stands for...i cannot remember. but the accessory wire comes on before the ignition wire....when you turn the key to accessory. make sure you test the wire before using it...!!!
i'll post what RAP is as soon as i find out...
