access port and zex nitrous system
Old Jun 26, 2009 | 05:59 PM
rxat2012's Avatar
i have been looking but cant find anything on using the two at the same time........ or if it is even possible........any help would be much appreciated
Old Jun 26, 2009 | 09:57 PM
yes, very possible.
Easy_E1 has a 75shot and Mazdamaniac has done extensive tuning to the car to assist with the Nitrous.
Old Jun 27, 2009 | 02:48 AM
archiei40's Avatar
offtopic but, will the AP be effective for the NA at all? I mostly see people use it on their FI'd 8's... but I really don't wanna FI my 8... was thinking bout nitrous tho haha.
Old Jun 27, 2009 | 11:10 AM
archie: you really should do a bit more reading up on the AP.
Most of us who use the AP are NA.
Old Jun 27, 2009 | 11:19 AM
Kane's Avatar
Senior Member
Nitrous is FI....
Mira... Mira - it's the SAAAME thing!
BTW - AP is a tuning tool; Nitrous is a Mechanical Tool - think hardware vs software - you use them both.
Old Jun 27, 2009 | 01:06 PM
myriadshalaks's Avatar
rot8ing
just to add to what has already been said, as charles ray hill tells me, once you have a good tune, a wet nitrous system is just a bolt on (as long as you stay below 55shot) and requires no further tuning.
Old Jun 27, 2009 | 02:15 PM
Easy_E1's Avatar
AP and Nitrous,,, A marriage made in heaven.
Old Jun 27, 2009 | 05:21 PM
04RX8man's Avatar
Rotary Powered Countryboy
AP is like heaven in a box!...from what i've heard since I dont' have mine yet
Old Jun 28, 2009 | 12:40 PM
Charles R. Hill's Avatar
Owner of BHR
Chase, thanks for listening, understanding, and conveying it just as I told you. Few people are as capable.
The only way that a Cobb AccessPort helps a nitrous system to run better is by virtue of the fact that the AP allows us a more optimal tune BEFORE the nitrous is added. For example, an engine that is tuned too rich, even with a properly calibrated nitrous system, will still run too rich when the nitrous is used. Lean out the host engine and everything will work in a more synchronous fashion.
Since the factory PCM was not designed with external triggers/ input channels we are stuck with this scenario.
Old Jul 10, 2009 | 03:47 PM
rxat2012's Avatar
ok i have the zex wet kit installed with the ap, some plasma direct coils, a cat back, and a hollowed out cat, with 50,000 miles on the motor.... how large of a shot can i run ????
Old Jul 10, 2009 | 03:49 PM
dozer's Avatar
on his 3rd rx8
50 shot...you will need extensive tuning to get where easy is at
Old Jul 10, 2009 | 03:58 PM
dozer's Avatar
on his 3rd rx8
i know absolutely nothing, i thought maybe that would be a baseline to some guidance...i know easy said he needed a lot of tuning to get to the point where hes at...
that is all
Old Jul 16, 2009 | 06:50 PM
ATX Mazda Fresh's Avatar
Yeah, well..........
The factory PCM is not designed to allow for accomodation of nitrous use. It works for F/I becase that is an airflow-based application and not chemical-based. There is no way to trigger the PCM to toggle between an N/A tune and a nitrous tune, either.
So you can't run a stage 1 with a stock PCM? also is it possible (I'm sure it is) to run a Stage 1 Zex Kit 35-50 shot on an Auto Rx 8 ?
Old Jul 16, 2009 | 07:21 PM
MazdaManiac's Avatar
Tuning the AP has nothing to do with "higher shots". MM and Easy refuse to believe me, yet, but they'll realize I am correct........... eventually.
Well, since the nitrous "shot" does not discern between loads and is always delivering the same amount of juice regardless of demand, there is a LOT of tuning that can be done to manipulate the WOT fueling to work more harmoniously with the added gasses.
On Erick's car, I have been gradually leaning the low RPM, high load regions to the limit so that it is not entirely too soggy down there.
Old Jul 16, 2009 | 07:32 PM
We'll see about that, partner.
Are you saying you can tune the AP in such a fashion so as to "work harmoniously" with the added fuel/nitrous while NOT effecting the non-nitrous mode?
In effect, yes.
The areas where the RX-8 is not prone to knock can be run significantly leaner than optimal.
Of course, you would be losing 2% - 5% power there at WOT, but why are you driving WOT with the juice off, anyway?
Old Jul 16, 2009 | 07:36 PM
Yes, you can, and I pioneered it 5 years ago. That was one of the things that led to the creation of BHR. What I was saying is that the factory PCM does not have an aux input channel because Mazda could not have cared less about what we in the aftermarket wanted to do. As such, the best we can do (other than adding a piggyback EMS) is tune the N/A application as best we can and then add about 55-60 h.p. worth of fuel/nitrous on top of that. BHR does have a product idea on the project board that will help us achieve higher shots (like 75-125 h.p.) rather easily.
As for A/T applications Easy_E1's car has been BHR's whipping boy and, although nitrous will work, it has to be handled with caution as the TCM likes to mess things up a bit.
THX that helps I'm thinking my Next Huge Purchases are The Safe Shot and The CobbAP
Old Jul 16, 2009 | 07:42 PM
let me handle calculating the proper custom fuel/nitrous jetting for the RX-8, willya?
Technically, it can't be done without a progressive controller.
Old Jul 16, 2009 | 07:46 PM
Seriously, I would suggest the AP, BHR Ignition System, a midpipe of some sort (maybe the BHR version), and then the nitrous. I have damned good prices on Zex stuff and I can tutor you on the install for free, too.
Could you get me an estimated price for all the above, Zex is all about easy install lol and my paychecks aren't crazy so thats why that zex kit is about 314.96 Thats damn good fo mee
Old Jul 16, 2009 | 07:48 PM
Technically, let's split hairs. You and I view this matter from 180-degree opposite perspectives and neither one may be incorrect. However, we are talking street cars, simple boosts in power, and keeping it all affordable.
For sure, but its not splitting hairs at all.
Does the fuel jet know what the airflow is?
Old Jul 16, 2009 | 07:57 PM
No, because the fuel jet is an inanimate object.
Well, yes.
The total fuel introduced into the engine determines the maximum potential dynamic housing pressure.
Amongst other things.
But the point is that a fuel jet will introduce the same amount of fuel at all times, regardless of the fact that the engine needs less at low RPMs and more as it reaches the torque peak.
Which is why I taper the fuel delivery in a complimentary fashion.
Not optimal, but certainly less suboptimal than having an over-rich condition down low and far safer than a lean condition up top (where it can actually do damage).
Old Jul 16, 2009 | 08:01 PM
bse50's Avatar
#50
RPM\LOAD operated regulator? like a boost controller but for the jets and not pressure operated. Must be expensive though...
Ok, now go back talking about serious stuff
Old Jul 16, 2009 | 08:11 PM
bse50's Avatar
#50
Yep, the big deal is not even picking up the rpm signal, the problem is making a variable jet. A valve on the nitrous line? That could be vacuum operated too. The problem is not talking about it, is crafting it!
I pmd you btw
Old Jul 16, 2009 | 08:20 PM
Originally Posted by bse50
Ythe problem is making a variable jet.
Its called a solenoid and its how the "big boys" do it.
It is utilized by a "progressive nitrous controller" - something that Easy and I have talked about at length.
However, in regards to the "pragmatism" that Ray is talking about, the fact is that RX-8 customers are mostly cheap bastards and NO2 users are an even cheaper sub-set of customers that are unlikely to spend the money needed for a progressive controller.
They just want to hit that button and see Vin Diesel go streaking by.
Old Jul 16, 2009 | 08:40 PM
Kane's Avatar
Senior Member
I suppose hand loaders are out of the question?
By hand loader I mean pressure regulated flow....sorta like a FPR only for Nitrous... use a MAP as a variable pressure regulator?
Old Jul 16, 2009 | 10:57 PM
wcs's Avatar
wcs
no agenda
Dude.... that cuts me deep...
