FYI: Weight of 245/40-18 on Stockers
Old Jun 21, 2009 | 10:10 PM
TX FYI: Weight of 245/40-18 on Stockers
46.0lbs. Sorry for the crappy cell phone pics.
Old Jun 23, 2009 | 11:16 PM
I just read that the stockers and the stock bridgstones should weigh more.
Old Jun 24, 2009 | 12:34 AM
is this with fresh tires or worn tires?
Old Jun 24, 2009 | 01:08 AM
Juice's Avatar
I made some poos
Totally depends on the tires used.
Stock bridgestones have alot of sidewall reinforcement so they are pretty heavy for their size. Toyo T1Rs in 245 are lighter than the stock RE040s in 225.
It would help if you let us know which tires you are using and if they are new or worn. If they are worn it should be noted the tread depth in 1/32 increments using a depth gauge. Not just that they have a certain amount of miles on them.
It seems like you are making a blanket statement that 245/40/18s will be lighter with this post and I would hate for someone less informed to just go out and buy 245/40 tires thinking they will be lighter when in fact they may not be.
Old Jun 24, 2009 | 05:57 AM
robrecht's Avatar
The wheel/tire combo on my Miata is 22.5 lbs (CE28N + Toyo T1R 1).
Old Jun 28, 2009 | 07:09 PM
Oh Sorry these are Hercules Raptis WR1's and they are about three months old, about 3000 miles, and one autox run (only one run due to a alternator problem) on them. These tires are just as good as the BFG made Raptors I had previously and both the Raptors and the Raptis' were better than the stock Bridgstones.
I can get these tires at cost ($400.00 for four) which is why I don't run the norm. I've spanked too many guys running tires that cost twice as much so I never saw a reason to run the expensive tires. The spec say the tire weighs 24.69lbs new which means the stock rims are pretty light.
File Type: pdf
New_Mazda_Guy
NW RX-8 Forum
Sep 19, 2019 11:20 AM
Ian_D
Rotary Swaps
26
Jan 21, 2017 02:23 PM
hufflepuff
May 30, 2016 10:45 AM
