side marker blinker issue
Old Jun 18, 2009 | 11:11 PM
blamerobb's Avatar
so i found a good diy about how to do this... only thing i was concerned about doing was cutting one of the black wires at the top of the connector on the side marker... only thing is there are two black wires....which needs to be cut? and why would this be cut completely? dont you need both wires running to something? i already cut some incorrect wires and one of my grounding wires for my parking light please advize
Old Jun 18, 2009 | 11:17 PM
04RX8man's Avatar
Rotary Powered Countryboy
what exactly are u trying to do to your blinker lights?
Old Jun 18, 2009 | 11:18 PM
Robb: are you trying to get your side markers to blink?
Old Jun 18, 2009 | 11:21 PM
blamerobb's Avatar
yes jedi
heres the link i am using
https://www.rx8club.com/showthread.p...diy%3A+blinker
Old Jun 18, 2009 | 11:24 PM
04RX8man's Avatar
AHH jedi and I to the rescue as usual!....and Jedi will prob beat me to the solution as usual!
Old Jun 18, 2009 | 11:29 PM
blamerobb's Avatar
i hope so.. haha. i am confused on this i already choped wires and need to solder them back... i want to be sure.. so green and black wires to? and cut which black wire
Old Jun 18, 2009 | 11:32 PM
Alexb's Avatar
desperately needs a drop
Well, I'm not sure about what wire. But it looks like you cut it completely. On that DIY there was a paint drawing, so to answer your one question, yes it gets completely chopped.
04RX8man's Avatar
from the sounds of that DIY you're cutting the wire completely to you can wire in the blinker all the blinke is doing it controling power or ground....acts like a switch sort of....either cuts power or cuts ground to the light.....
Old Jun 18, 2009 | 11:34 PM
04RX8man's Avatar
^that's what I think i'm getting from it let me read over it again and see what i see on the second time
Old Jun 18, 2009 | 11:35 PM
blamerobb's Avatar
ya thats what i thought but there are two black wires. this says gut the black wire.... which. haha
Old Jun 18, 2009 | 11:36 PM
blamerobb's Avatar
cuz ones ground and ones power i am assuming but which is which?
Old Jun 18, 2009 | 11:43 PM
04RX8man's Avatar
well you might b able to find where the one is grounded somewhere nearby...but if not it really shouldn't matter I wouldn't think...all you are doing is breaking the connection to the bulb so whether u break the connection at the ground side or power side wouldn't matter...
Old Jun 18, 2009 | 11:46 PM
blamerobb's Avatar
hmm makes sense but if you read the diy. he says 3/4 dosent work then you need to solder the black and red wire.. theyre both BLACK
blamerobb's Avatar
maybe i am just overthinking it. i should wait till sat dozer has it done i can look at his too. just confused
Old Jun 18, 2009 | 11:49 PM
04RX8man's Avatar
Where the hell is Jedi on this one...we could use his input also
Better not be asleep or something yall are 3 hrs behind me and i'm still trying to figure this out! haha
Old Jun 18, 2009 | 11:51 PM
04RX8man's Avatar
Yeah i read that DIY again and it is a little bit confusing if I had my 8 right here in front of me I could prob b of more help but it's just not worded too well
Old Jun 18, 2009 | 11:53 PM
blamerobb's Avatar
right? its confusing. i was like
Old Jun 18, 2009 | 11:55 PM
04RX8man's Avatar
haah yeah I hear u it seems to be simple enough but there is alot of colors thrown around when he's describing it haha...
Old Jun 18, 2009 | 11:58 PM
blamerobb's Avatar
ya i know and if you look at your car. its like uhhhh.. and i connected the bottom green and black wire no the top blinker. i was like ughhhhhhhh
Old Jun 18, 2009 | 11:59 PM
04RX8man's Avatar
from the DIY it seems that when he says is 3/4 don't work etc etc....that doesn'tt have anythng to do with the black wires you cut and solder to the blinker wire....it just has to do with the wires to the side marker connnector...whatever that means!
Old Jun 19, 2009 | 12:02 AM
Kaiser bun's Avatar
Yeah Sioux Sioux!!!
Originally Posted by fray
What follows is my first DIY, which adds blinking ability to the side marker lights. Note, since this modifies your electrical system, it could cause a fire, something to break, etc, etc... I.e. don't come and bother me if it doesn't work for you or your burn your car!
haha why dont you ask him... o wait ^
Old Jun 19, 2009 | 12:08 AM
04RX8man's Avatar
^haha also a good valid point maybe we shouldn't b reading into this thing too much haha
Old Jun 19, 2009 | 12:09 AM
blamerobb's Avatar
^^lol ya i could
Old Jun 19, 2009 | 12:51 AM
Alexb's Avatar
could you not strip a bit of the wire off, and test which is power and which is ground with a multimeter? and then use electrical tape to recover the stripped portion?
Old Jun 19, 2009 | 12:54 AM
sorry guys, I was packing for the big Vegas Meet tomorrow.
Robb: did you get it figured out? (was too lazy to read all the posts)
