Motomouse
06-18-2009, 04:31 PM
Guys I need help. I bought nexus gauges and need some help to wire them correctly.
I need to connect one wire to constant +12v source(musst stay powered during engine startup and while ignition switch is off) and one wire to switched +12v source(must stay powered during engine start and crank but turn off when the ignition switch is off).
As a first wire for me looks like its a battery +?? but for the other I dont know and appreciate some help.
I want to install those on the weekend hope to get some answers :)
Motomouse
06-18-2009, 04:32 PM
Thank you to BHR (Ray) for a great deal on those Nexus gauges!!
nuke0907
06-18-2009, 04:37 PM
so, you're trying to find a switched source? use the cigarette lighter.
Jedi54
06-18-2009, 04:51 PM
yup, Cig lighter should do the trick
Motomouse
06-18-2009, 08:26 PM
I was thinking about that hope it will work :)
Motomouse
06-18-2009, 08:30 PM
Any chance I can get the other one connected somwhere near the cigarette lighter I dont want to go all the way to battery ?
Thank you
nuke0907
06-18-2009, 08:35 PM
if you have a multimeter just check around for a wire that has voltage when your car is off. if not, the red wire in your stereo wiring harness will do the trick.
Motomouse
06-19-2009, 07:02 PM
Thanks Nuke :)
I dont have the multimeter but your help should be enough
Thanks again !!
chickenwafer
06-19-2009, 08:37 PM
For constant power you can goto the driver side fuse box kick panel
nuke0907
06-19-2009, 11:04 PM
that works too. you'd have to run some wire, but at least you don't have to go to the battery.
Motomouse
06-20-2009, 01:40 PM
maybe I will try the fuse box. But now we have rain in jersey and I will have to wait till tomorrow or next weekend :(
tksnobords
07-05-2009, 12:46 AM
http://www.rx8club.com/showthread.php?t=177199
the 12V is in the drivers kick panel, there is pictures. you also might be able to grab it at the ignition.
Motomouse
08-05-2009, 09:56 PM
Thanks guys for help I use the wires tksnobords talk about. The gauges works fine for over two weeks already and I love it :) looks better than i was thinking now the only think it worry me is my oil temp :) if its hot and iam in the traffic the oil get pretty hot but no cash for oil cooling fan mod now
