what pipe is this?
Old Jun 16, 2009 | 10:00 PM
always.anthony's Avatar
is looking for his torque
what pipe is this?
to the right of the washer fluid bottle, there are 4 pipes, what pipe is the bottom left one? i can get my amp wire through that, and was wondering if it would be bad to run a power wire next to that pipe.
it won't let me upload the photo
Old Jun 16, 2009 | 10:17 PM
ZumnRx8's Avatar
RX8 & RX7 owner
pics, where are you located?
Old Jun 16, 2009 | 10:21 PM
expo1's Avatar
He's as bad as Can
Found the below pic in another thread. The ones to the right look like AC lines. Did you also look at THIS thread?
Old Jun 16, 2009 | 10:27 PM
ZumnRx8's Avatar
RX8 & RX7 owner
uk 8,
Old Jun 16, 2009 | 10:48 PM
yeah that's the area i'm talking about, it should be behind the second bottle on the right.
quote from stealthtl " I used an easier way thru the firewall - about six inches inboard from where you drilled is a big grommet for the heater tubes.
A slit in the rubber, a coathanger thru it, then pull the wire thru - no drilling.
Don't even need to unbolt the washer bottle!"
Old Jun 17, 2009 | 09:57 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah those would b a/c line.....also you are right at your intake manifold...I say no to running your your wire near tthat stuff!
Old Jun 17, 2009 | 05:43 PM
Not to sure those are AC lines.
Better ask Dozer.
He's our resident pipe specialist. He smokes alot.
Old Jun 17, 2009 | 05:57 PM
04RX8man's Avatar
^those are definately A/C lines...the brownish/tan colored one is the High or Hot side of the A/C. The stainless one above is the Low pressure or cold side of the A/C system
Old Jun 19, 2009 | 07:26 PM
thanks, i think its safe to run it against it, cause the strut brace deal thing our cars come with imo gets hotter than that.
Old Jun 19, 2009 | 08:07 PM
04RX8man's Avatar
that high side gets pretty damn hot but ti's your car!
mdl0209
May 23, 2019 05:46 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
arexatemate
Nov 7, 2015 02:27 PM
r-enzyme
Oct 1, 2015 01:27 AM
FubarI33t
Sep 28, 2015 08:45 PM
