Two speed rear?
Old Jun 15, 2009 | 10:31 PM
Banner's Avatar
Two speed rear?
Looking at the gear ratio on the new rx-8 (4.77) I have to stop and wonder if anyone is making a two speed rear for it? Mainly so you could get better mileage when on the highways and you're not as worried about performance. And it would probably be easier to install than to mess around with MT gear ratio's.
(anyone else wonder why they didn't make the 6th gear a lot taller for better hwy mileage?)
Old Jun 16, 2009 | 06:20 PM
04RX8man's Avatar
Rotary Powered Countryboy
^maybebecause below 3k rpm(60mph in 6th in the 04-08 rx8's) almost bogs the motor down and starts to seem to use more fuel(at least in my findings)
Old Jun 16, 2009 | 06:33 PM
kartweb's Avatar
Strange as it might seem it may actually improve the fuel mileage to rev a bit higher.
If I set my cruse control to 60 MPH on a 90 mile drive down a flat freeway I get 21.3 MPG. At 70 MPH I get 21.7 MPG despite the increased drag. I've tried that about a dozen times on my daily commute.
Normally I drive 75-80 with bursts to 90 and pretty much average a tad over 20. Except when I have some city driving...
Best MPG I've seen was a bit over 23, worst I've had is about 16. I don't flog the car more then a few times every tankfull.
Keep in mind I run a 20% ethanol mix.
Old Jun 16, 2009 | 06:39 PM
04RX8man's Avatar
^exactly
Old Jun 18, 2009 | 07:09 PM
Would you be willing to spend $3000 to have it?
Next ....
Old Jun 19, 2009 | 07:36 PM
Banner's Avatar
Next ....
Maybe. Got something in mind?
Old Jun 19, 2009 | 08:22 PM
04RX8man's Avatar
^3k for a diff? I'll pass thanks!
drebbrnator
Dec 27, 2018 07:02 PM
RZ1
Aug 24, 2015 01:04 PM
D13
Aug 22, 2015 11:42 PM
AussieGray
Jul 16, 2015 03:58 AM
