Helmet with more headroom
Old Jun 12, 2009 | 01:30 PM
mdw1000's Avatar
I'll snap his neck.
Strange thread title, I know...
I currently have the G-Force open face helmet. It is a comfortable helmet, but I'm not able to adjust the seat exactly how I like it because I run out of headroom.
Are there helmets out there that would be "thinner" on the top of the head and still have the required rating for track days? It would be nice to get some more headroom. Or am I just SOL?
Anybody have a similar issue, make a switch, and have it improve?
Thanks in advance!
Old Jun 12, 2009 | 01:32 PM
dozer's Avatar
on his 3rd rx8
sol indeed
Old Jun 12, 2009 | 01:36 PM
expo1's Avatar
He's as bad as Can
You can get a seat lower to the floor, thats what I did. A search for 'Helmet" will bring up those threads.
Old Jun 16, 2009 | 07:58 AM
Race Roots's Avatar
Former Sponsor
Yeah I Ran into the same problem, I now have some Bride Gias Low Max on order now. I have never really seen a thinner helmet.
Old Jun 16, 2009 | 01:47 PM
bingo's Avatar
Playing in parking lots
I have friends who increased their headroom by going from open face to a full face model. One fellow went from a Bell Mag4 to a KBC full face model (M2005 cert) and found he didn't bounce off the headliner nearly as much.
You'll have to find a shop with inventory and try helmets on, it would depend on the shape of your head and finding the right helmet.
Old Jun 16, 2009 | 02:02 PM
dezodwest's Avatar
Buying new seat that sits lower is the best bet either way. I'm 6' tall and once and a while I smack the roof.
Plus the factory seats don't hold you in well anyway. I find myself more tired than I need to be after a longer session because a lot of my energy is put into keeping my body in the seat. A god aftermarket seat will fix three things. Less weight, more strength/stamina, and helmet clearance.
Old Jun 16, 2009 | 05:21 PM
mdw1000's Avatar
I'll snap his neck.
I found that using a CG Lock seems to help quite a bit with holding you in place, decreasing fatigue, etc, etc.
Old Jun 16, 2009 | 05:22 PM
mdw1000's Avatar
I'll snap his neck.
I've thought about trying a full-face, but I also heard that full-face helmets are not ideal to use with airbags. Thoughts?
Old Jun 16, 2009 | 06:35 PM
midlife crisis's Avatar
NE
I had another problem last week at a SOLO. The right front corner of my seat (under my right thigh) collapsed on a long right sweeper. This is with manual seats set to the highest setting. Any explanation or solution? It did seem to reset after another lower/raise cycle but I'm not trusting it.
Old Jun 16, 2009 | 06:37 PM
Soloseven's Avatar
I had a open face Bell Magnum 4 and a 2005 Touring with a sun roof. The sun roof takes out a inch of head room by itself. I just fit but could not turn my head with out touching the head liner (I had a dark spot on the head liner where my helmet hit). I went with a HJC open face AC-3 Carbon. It didn't look lower than the Bell since it has a wind scoop on the top but it is. (its a motorcycle touring helmet) Since it was thinner than the Bell I was amazed I could turn my head, you need to turn your head in solo racing. The HJC is DOT & SNELL approved. It also is much lighter than the Bell since its carbon fiber. So after reading all the good things on this helmet your about to say "What's the Price?" $300 list. Keep the diver dan closed face specials I'm good with this light weight, low profile open faced super helmet.
http://www.hjchelmets.com/
Old Jun 17, 2009 | 12:58 PM
dezodwest's Avatar
Yeah I've read into that before and it doesn't seem bad at all. I like the idea of sitting lower and shedding quite a bit of weight off the car. For a budget racer, I think the G-Lock is a great solution and I'm glad you mentioned it.
Old Jun 17, 2009 | 10:32 PM
mdw1000's Avatar
I'll snap his neck.
Although from what I can tell the "stock" CGLock will not work with our seatbelt because of the design, but someone did mention to me that you can install it "backwards". I use the "Instructor" version of the CG lock which seems to work fairly well.
Old Jun 19, 2009 | 03:45 PM
stephenti's Avatar
You can either install it backwards, or just install it the correct way up, and exclude the bottom piece of the tongue on the CG Lock.
When you go to use it, just slide the guide/tongue of the CG Lock into the seatbelt buckle slot, BETWEEN the belt and the plastic. The width of the CG Lock tongue keeps jams it against the buckle once you cinch up. Even better, & works great.
Old Jul 7, 2009 | 12:28 AM
SpIcEz's Avatar
hmm
I always just push the seat back a little,
give the seat belt a tug and lock it,
then move my seat forward and push a little against the locked seatbelt.
- Tight seat belt, wont unlock if your pushed against it enough.
- Free, 40$ more in my pocket.
- Works on all cars.
