final drive question
Old Jun 9, 2009 | 10:16 PM
kevinD1226's Avatar
MA final drive question
im reading alot about the final drives in the rx8s and a few people have swapped over to the 4.777 final drive and they love it but is this a direct bolt on or do u have to have the differential modified to make it fit? will it be worth the cost? ive searched and have gotten back mixed results but i wasnt sure how old the thread was or if theres been any new changes on this.. any help is appreciated, i did use the search button but still am a bit confused on this
Old Jun 9, 2009 | 10:38 PM
rx8thunder's Avatar
Being (new) single rocks!
Going with 4.777 diff, you need to have a skilled transmission guy open up the back axel and replace it. In so doing it will fit just like it does on the 09's but will require some shimming to make sure it's perfectly secured and lined up.
It's a great mod, well worth the money.
Old Jun 9, 2009 | 10:44 PM
kevinD1226's Avatar
thanks i appreciate the help and the non bashing for not beeing able to do a more thorough search
Old Jun 12, 2009 | 01:34 AM
Zelse's Avatar
悪魔のR
About to make a thread about it.. I just got mine. Great power increase I noticed, still getting used to the whole shifting much earlier..but when I let off the gas I notice a REALLY weird sound. I'll post about it now, but if anyone knows the answer that'll help..thanks.
Old Jun 18, 2009 | 12:12 PM
padilla08's Avatar
i heard that after installation, you'd have to calibrate some stuff with the speedometer. and you'd need a kit to do so. what do you need to know about that? or was that BS? haha! thanks
Old Jun 18, 2009 | 12:24 PM
Zeon's Avatar
Keep in mind that if you are planning on ever going FI you probably want to reconsider this mod. I'm no expert, but I'm pretty sure there are some FI guys out there looking for longer gears instead of shorter ones given by this final drive ratio.
Basically, while you may like the extra low-end power now, if you later have a significant increase in power, this mod may not be very good for you.
Old Jun 18, 2009 | 12:35 PM
rx8thunder's Avatar
Speedo is NOT affected!
Old Jun 18, 2009 | 12:42 PM
alan23's Avatar
For RX8, I think the speed sensor is not taken off the engine revolution, so the FD has no impact on the speedometer. My rpm increased compared to the same speed before and after my FD mod.
Cheers
Alan
Old Jun 18, 2009 | 12:43 PM
ChrisRX8PR's Avatar
13B-RE
I am actually debating on going 4.10 or 3.90...the way it is now...its crazy.... :P
Chris
Old Jun 18, 2009 | 12:53 PM
rx8thunder's Avatar
If you go FI, just sell 4.77.
Old Jun 18, 2009 | 01:11 PM
philipchan's Avatar
As far as I know is there are 2 ways to do the 4.77 diff
one is as you said, that's changing the gears in the diff, 2 rings
you really need skills to do that, if you dont do it right, you will **** up the diff
the second way is replace the whole diff, that's easy, but costly tho, over $1000 for the whole diff where the rings for only $300 or so
Old Jun 18, 2009 | 01:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
^agreed
Old Jun 18, 2009 | 01:21 PM
rx8thunder's Avatar
I got an expert to switch the internal gearing with new shims for $150. A general mechanic took out the diff unit and put back in for $100. The gear itself should cost you no more than $600
Old Jun 18, 2009 | 01:26 PM
philipchan's Avatar
That's a good deal, only charge you for $150 labor for internal gear !!
Old Jun 19, 2009 | 05:33 AM
Zeon's Avatar
Chris
I can't imagine your setup... Do you have a custom tranny yet? I believe that Fluid was saying he was going with a 3.9 for his sometime in the future.
Old Jun 21, 2009 | 09:06 AM
padilla08's Avatar
http://www.ricks2k.com/products/yellowbox.php
speedo IS affected. not too much, though. if you want more accurate speeds, though, check this out. not bad.
Old Jun 21, 2009 | 10:15 AM
rx8thunder's Avatar
^ Don't know what you are talking about. It is NOT affected on an RX8
Old Jun 21, 2009 | 01:14 PM
shazy's Avatar
I hope you know it's not affected....
edit: Woops had this page opened for 3 hours...
Old Jun 21, 2009 | 03:11 PM
staticlag's Avatar
The Professor
Speedometer isn't affected. Pretty sure that the speed reading is taken off the wheel axles. Means that only wheel or tire changes would affect the speed ometer.
Old Jun 21, 2009 | 03:44 PM
rx8thunder's Avatar
^ Correct
Old Jun 22, 2009 | 09:30 AM
padilla08's Avatar
"This 1-2 percent error can be magnified even further when you install aftermarket wheels and tires or change the rear GEAR SET." that's in the second paragraph of the link i sent.
also, check out this thread. they mention the yellow box constantly.
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/4-778-final-drive-%24296-77054/
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
Pelleilee
Sep 29, 2019 10:07 AM
sccarally
Gulf RX-8 Forum
Sep 8, 2015 10:34 PM
k4thomas
Aug 5, 2015 03:03 AM
