flooding
Old Jun 8, 2009 | 08:28 AM
sparky1406's Avatar
flooding
my car keep flooding i am leting it warm up im not runing it hard tell its warmed up any ideas
Old Jun 8, 2009 | 12:37 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
1. Go to the dealer
2. Use spelling and grammar check
Old Jun 8, 2009 | 12:39 PM
CTrx8's Avatar
space for rent
what do you mean it keeps flooding? how did you de-flood and did you get the dealer to go through to change the plugs? do you have the old starter or the upgrade?
Old Jun 8, 2009 | 12:42 PM
it keeps flooding? What 'de-flood' method are you using?
year?
miles?
any substantial modifications to the vehicle?
Old Jun 8, 2009 | 01:48 PM
UrbanOcho's Avatar
Stick Specialist
Originally Posted by CarAndDriver
1. Go to the dealer
LOL
Old Jun 8, 2009 | 04:19 PM
MICHGoBlue's Avatar
Couldn't agree more.
Definitely get the vehicle checked to see what Mazda has to say.
Old Jun 8, 2009 | 04:57 PM
you guys are missing out on the OP's other new thread today.
Old Jun 9, 2009 | 05:39 AM
sparky1406's Avatar
04 no mods 50,000 miles
I take it to the dealership and they keep telling me that I am not letting it warm up which I always do. This is the fourth time it has flooded and the mechanic says that rotary engines have this problem.
Old Jun 9, 2009 | 07:03 AM
Ace of Spade757's Avatar
No one has mentioned searching yet, I'm amazed.
Old Jun 9, 2009 | 07:10 AM
PSTNLSS's Avatar
The Former PSNTLSS
Stop parking near the water
Old Jun 9, 2009 | 07:54 AM
RIWWP's Avatar
You likely have a weak ignition, either because of failing plugs, failing coils, failing battery, and/or failing/weak starter.
The RX-8's "flooding when cold" issue is largely solved with updated flashes, and really only happens when the ignition is weakened by one or more failing components.
Old Jun 9, 2009 | 08:15 AM
JinDesu's Avatar
went back to srsly broke
Old Jun 9, 2009 | 11:38 AM
do you have the invoices of the 4 times you've gone to the dealership for this issue? I'd like to know what was done to correct the issue.
did they replace any parts?
plugs, starter, battery ???
Old Jun 9, 2009 | 11:57 AM
Shijin-Kun's Avatar
Rotary Power!
Before i got my new engine my car would struggle to start till it ended up flooding itself. I would recommend what everyone else is saying get plugs coils checked.
Old Jun 9, 2009 | 12:08 PM
RIWWP's Avatar
^ and generally if your plugs are bad, your coils are too. I haven't seen a single report on here of plugs needing to be replaced for reasons other than fouled due to flooding (or racing applications, but that isn't the issue here), and nearly every flooding issue in the past few years is weak ignition, either from the starter or failing coils. Normally coils.
Old Jun 11, 2009 | 11:04 AM
sparky1406's Avatar
the last time i went to the shop thay just changed the plugs i will check the cloils
Old Jun 11, 2009 | 02:45 PM
leadguitarist05's Avatar
hey guys, maybe someone here can give me some advice... my car is an 04 with 75k on it and it has flooded for the first time... my bad, I moved to from one side of the street to the other to avoid getting a parking ticket, lesson learned... my plugs are out and fouled crazy from being flooded (to be expected), my question is how do I clear out all the residual fuel and oil so that I'm not putting clean plugs right back into a flooded engine... note that I tried the deflooding procedure prior to pulling my plugs, I even pulled the fuse to the fuel pump to make sure... is there some kind of spray or something I can buy to make sure there's no crystalized residue left in the trichoidal chamber? can I just turn it over a few times with the spark plugs removed and the fuel pump fuse removed to blow out any excess?
Old Jun 14, 2009 | 12:11 AM
04RX8man's Avatar
Rotary Powered Countryboy
^yes remove the fuel pump fuse and leave plugs out and crank should get all the excepp fuel out and your new plugs will b good 2 go.
Old Jun 14, 2009 | 12:22 AM
JGR4444's Avatar
GR
i can NOT believe that this thread is not getting flamed left and right... people really need to learn the search method... i am pretty sure flooding is the most searched for topic on our beloved website and there is more information on it than there is in some school books. SEARCH
92trbolzr
May 18, 2025 09:04 AM
DylanForbes
25
Oct 31, 2017 05:47 PM
fistofmeat
Oct 7, 2016 12:15 PM
Danield97
Oct 10, 2015 05:58 PM
iphil
Sep 21, 2015 10:49 PM
