View Full Version : Headlight positioning sensor question
Big Money Pit
06-07-2009, 10:14 AM
I have aftermarket springs on my car, and so in order to get them on there i had to undo this sensor. When i put it back, i put it back just like it was, and now my dash light for the leveling sensor is always on. Is there a fix for this with lowering springs?
DarkBrew
06-07-2009, 10:35 AM
The lowering springs do not affect the position sensors.
You may have damaged your sensors or wiring; either the front or the rear.
Maybe you can take some pictures and let everyone have a look
Big Money Pit
06-07-2009, 10:42 AM
they're only on the drivers side, correct?
i don't think i damaged them... i was very careful with them.
DarkBrew
06-07-2009, 11:00 AM
Yes, driver's side front and rear. Did you disconnect them or just set them aside?
Are you sure that the sensor arm is in the correct position?
There's also a lot of information in this TSB
http://www.finishlineperformance.com/pdf/rx8/bulletin/09-008-07-1729a.pdf
I had my connectors sealed up to prevent corrosion.
Jon316G
06-07-2009, 11:03 AM
Its a known problem with people who lower their springs because the sensor is on the rear anti-roll bar.
Read through the "RX8 Interesting Facts" list.... its on there:
http://www.rx8blog.com/mazda-rx8-interesting-facts/
DarkBrew
06-07-2009, 11:16 AM
Yes, lowering can affect headlight aim but should not cause a warning light.
The common cause of the headlight aim warning light is corrosion. Water gets in through the connector.
The second leading cause is improper installation....
G3tR3DDY2GR3DDY
06-07-2009, 11:32 AM
no...
Jon316G
06-07-2009, 03:48 PM
Ahh... I see.
Big Money Pit
09-06-2009, 02:18 PM
ok, the light is still on. i've attached some pictures of the front and the rear. everything looks normal to me. keep in mind... this only occured immediately after i installed my lowering springs and the light has been on ever since.
the first three are the rear sensor, from the back of the car.
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1067-1.jpg
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1068.jpg
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1069.jpg
and these next four are the front sensor:
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1071-1.jpg
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1072-1.jpg
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1073-1.jpg
http://i233.photobucket.com/albums/ee148/biblebelts/IMG_1074-1.jpg
Big Money Pit
09-22-2009, 10:18 AM
anyone?
RaspyRotary
04-07-2012, 09:25 AM
Hmm... after debating whether or not to revive this.. I think I will.
Have you figured it out?
Looks like that front sensor connector is a bit dirty.. may want to pull it off, and have a look inside to see if the connections are corroding?
