WTB: 5V ref, 4-wire, 1-100psi, 1/8 NTP, pressure sender
Old Jun 1, 2009 | 06:14 PM
carbonRX8's Avatar
U-Stink-But-I-♥-U
The pressure sender that I recently got to use as a fuel pressure sensor turns out to be a 3bar sender, which is basically useless for EFI.
A oil or fuel sender will work fine as long as it meets these characteristics:
  1. 5V ref. I prefer a 4-wire version (as it will be mounted in an ungrounded location) but a 3-wire will work, I suppose as I could somehow ground it. I.e., the wires should be 5V sender supply, sender ground, signal + and signal -. A resistance sender will not work.
  2. This should be a 5 bar sender or 1-100 psi.
  3. Standard 1/8 NTP. I dont think I have ever seen other than this, but whatever.
Any info on where to get such a sender new for less than about $50 would be great as well.
