WTB some misc turbo parts
Old May 30, 2009 | 08:19 PM
05rx8mazda's Avatar
B.I.G
i need the wastegate actuator arm for the 3071r mm upgrade and the oil/water lines..
if anyone knows where i would be able to get those.. or could i use just a regular rubber hose or does it need to be steel braided?
Old May 30, 2009 | 09:43 PM
Mawnee's Avatar
I divide by zero
Oil will eat rubber hose. Bad mojo
Old May 30, 2009 | 11:36 PM
Psychofox's Avatar
我愛台妹,台妹愛我
go to summitracing.com , they have all kinds of hoses.
this is what i use for my oil return line
http://store.summitracing.com/partde...5&autoview=sku
i am sure you can use this for your water lines too
just choose the right size for your application.
As for the actuator arm, i believe it is custom made to the specific turbo you have, so you might have to contact MM.
Old May 31, 2009 | 12:14 AM
05rx8mazda's Avatar
B.I.G
hmmm i will have to contact mm but last time i pmed him he did not respond dont really wanna bother the man.
im trying to piece everything together right now.. is like a puzzle.
Old May 31, 2009 | 12:26 AM
chickenwafer's Avatar
Nope
Use high temp rubber hose for oil return, ATP sells it.
AutoZone should have the hose you need for the oil lines- high pressure fuel hose works.
ATP also may have the actuator arm
Old May 31, 2009 | 11:17 AM
G3tR3DDY2GR3DDY's Avatar
oil wont eat rubber hose wtf...
stock oil lines are rubber, what do you think SS braided lines are underneath? oh! rubber..
Old May 31, 2009 | 11:38 AM
DeViLbOi's Avatar
The devil made me do it
I am 99.9999% sure that Jeff has said not to PM him here as he has thousands of PMs and to just email him.
Old May 31, 2009 | 11:47 AM
05rx8mazda's Avatar
B.I.G
you just told me that. i did not know that. thanks for the heads up bro,
Old May 31, 2009 | 11:53 AM
05rx8mazda's Avatar
B.I.G
thanks will give ATP a look around.. now just eed to figure out the vacum lines and the oil return lines. lol i stayed up until like 3 AM piecing it together.. its put together ouside the car... sooo now i have a better idea of how it goes on.
Old May 31, 2009 | 05:46 PM
Mawnee's Avatar
I divide by zero
Oil lines are made of oil resistant rubber. The inner surface is also often hardened or plasticized to resist degredation.
Oil will soften and quickly wear regular rubber hose, just ask anyone that has ever mistakenly put oil in their brake master cylinder.
ax75f92
Aug 18, 2020 12:05 AM
RicerX1
Jan 11, 2016 05:59 PM
AllSeeingChris
Aug 16, 2015 12:35 PM
