2009 RX8 R3 FACE/OFF - Painted Headlight Housings!
Old May 30, 2009 | 07:23 PM
TheBlackmobileR3's Avatar
Considering my R3 is mostly black, the chrome in the headlights has GOT TO GO.... Its time to black these bitches out!
So here on day 1:
- Bumper removal
- Headlight removal
More to come as it happens... stay tuned...
Old May 30, 2009 | 07:29 PM
Id like to give thanks to Chef "shakeyourbrakes" for the baking instructions. You can check out his thread at https://www.rx8club.com/series-i-exterior-appearance-body-kits-27/painted-hid-headlight-housing-diy-yea-i-finally-did-144633/
Lets hope that 220 degrees is money! Ill find out in a little bit!
Old May 30, 2009 | 07:36 PM
shakeyourbrakes's Avatar
220s the magic number, dont forget the screws! cant wait to see the pics. Youve got cohones for tearin apart that 09, haha
Old May 30, 2009 | 07:40 PM
dozer's Avatar
on his 3rd rx8
subscribed! good luck, i wanna see how this turns out
Old May 30, 2009 | 07:44 PM
Spinning Sushi's Avatar
I <3 Sushi
Get rid of your VFAD while the bumper is already off.
Old May 30, 2009 | 07:57 PM
NgoRX8's Avatar
would be interesting to see. will you be blacking out all the chrome? will look great but make the lights useless except for the headlight.
Old May 30, 2009 | 08:14 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
wow looks like a crazy project! good luck! You should find a clear lens to replace that strip of orange lens.
Old May 30, 2009 | 08:31 PM
myriadshalaks's Avatar
rot8ing
i'm confused.
Old May 30, 2009 | 10:18 PM
Rotr8's Avatar
whines all the way home
Good luck, The 04-08 lights turned out just great but then again I didnt have to sand down chrome paint and repaint areas that are gonna affect the light projection,,,
Old May 30, 2009 | 10:29 PM
Update: just did the baking. 220 works, I wouldnt want to try it any higher and risk melting anything. You have to work it and put it back in 4-5 more times for 5 mins each time to reheat the glue and soften it. Not only do I have pics but I have been recording the process on video so I will be posting that as soon as I get it all back together in a day or 2. Gotta pick up some high temp paint tomorrow, this Krylon fusion I have isnt recommended for warm/hot surfaces. DOH!
NgoRX8- ALL CHROME is going black. As long as the highlight output is not effected I dont care about the signal and high beam. I'm going all out BLACK..... I dont like seeing people who leave portions chrome, it makes the headlight look broken and like pieces are missing.
Also, I took the amber reflectors OUT. I refuse to have em, painted or not they got to go!
The video should be good. I will be editing it all with subtitles and what not. Should help you guys out and feel more comfortable with the process as well as other car owners in general since its really the same process for most recent model cars.
Stay tuned.........
Old May 30, 2009 | 10:34 PM
Why remove the VFAD? I know its for the air intake but can someone point it out to me in one of my pics and explain why I would do that? (VIA PM to avoid a change in topic in the thread)
Old May 30, 2009 | 10:46 PM
Tomorrow: Scuff, paint, reassemble, MAYBE install.
Old May 30, 2009 | 11:01 PM
SiLVeRE8's Avatar
a.k.a. WhITeRE8
Nice job! I see that you are chinese? I am too lol!
Are you planning on reusing the glue, or apply new glue?
Old May 30, 2009 | 11:14 PM
hey nice man, just a quick word of advice. After you paint those and reassemble everything, make sure not to put them back together for at least 12 hours. The first time I painted mine, I let the paint basically dry to touch, which was about two to three hours, and I sealed them back up and put them back in. The next day I woke up to the inside of the lenses covered in a kind of fog all across the inside. After I took them out and back apart again, which was a pain in the ***, I realized that the "fog" was actually a layer of paint which adhered to the inside of the lens in the drying process. Since theres nowhere for the fumes to go, they attach to the lens... I had to sand the inside of the lens, all the from 400 to 1000 grit to get it off.
Lesson learned, the next time I painted them, I let them dry for about 20 hours, and didnt come across the problem again. Just a heads up!
Old May 30, 2009 | 11:19 PM
shakeyourbrakes - Interesting, Ive done quite a few sets on my past cars and never had that problem. It sounds to me like overspray. I have kept my lenses wrapped in syran wrap wince I got them apart to prevent any dust or paint from getting on the backside of the lens. I appreciate the heads up but I really have no idea what happened with yours, really weird.
What kind/ brand paint did you use?
Old May 30, 2009 | 11:22 PM
I will be reusing the existing glue and then once the headlight is assembled I will go around the whole seam with a good bead of silicone to prevent moisture entry.
Old May 30, 2009 | 11:23 PM
perks11's Avatar
HEADTURNER
im gonna have to think about this. i love the way they look on other cars.
Old May 30, 2009 | 11:47 PM
The evil demons...
Old May 31, 2009 | 01:49 AM
Fortunate Few's Avatar
Irollerblade.
everything looks good so far.
Old May 31, 2009 | 02:23 AM
Just did a bunch of reading and found a lot of people have used the Krylon Fusion paint inside their headlights with no problems from the heat of projectors. I went ahead and painted them satin black and they are drying right now......
Old May 31, 2009 | 02:24 AM
Mazdaspeed RX8 ver2's Avatar
im excited about this project cant wait to see how it turns out!
Old May 31, 2009 | 02:25 AM
Thanks bro
PS: This paint has me higher than Method Man when the power is out.
Old May 31, 2009 | 02:29 AM
i was planning on doing this soon, how hard is it to do? gonna be my first time opening up my headlights so im a little scared about doing this
Old May 31, 2009 | 02:58 AM
Hang tight my video Im putting together will help ease your nerves.... much like these spray paint fumes are easing mine.
Old May 31, 2009 | 03:34 AM
Nopstnz8's Avatar
Can't wait to see the final result!
