Engine coolant level light?
Old May 30, 2009 | 04:03 PM
CaptainEggs's Avatar
Exclamation Engine coolant level light?
My mom went for a drive today and when she came back she said the engine coolant level light turned on and when she hit the brakes it turned off. me and my dad checked the level but it was at the full marker. any idea of what this might be?
Old May 30, 2009 | 05:01 PM
myriadshalaks's Avatar
rot8ing
failing or failed sensor. replaced under tsb.
or you're low on coolant.
i say this once a day now.
Old May 30, 2009 | 05:04 PM
okay thanks
Old May 30, 2009 | 05:11 PM
cogsNsprockets's Avatar
nah, probably slightly below the level of the coolant and when your mother braked, the fluid shifted and uncovered the sensor or the other way around. When your father checked it, it was probably hot and therefore expanded in the tank to look full.
Check it when its cold.
Old May 30, 2009 | 05:14 PM
rot8ing
you'll see, cog. yours will do it too.
Old May 30, 2009 | 11:01 PM
yea ill see, but i added some just in case...
Old Jun 1, 2009 | 04:17 AM
J wind's Avatar
For me, my expansion tank had a crack somewhere, and I was told that its losing pressure which may of caused my CEL light to go off. It might be the same case for you perhaps?
Old Jun 1, 2009 | 05:54 PM
well i found the problem... we have a leak and idk what the part is. i think its the water pump?... and its nothing big but ill need to get it fixed asap.
vapor2
Nov 3, 2020 03:38 PM
Kim Jong Illest
Aug 6, 2015 02:34 PM
Nisaja
Aug 6, 2015 01:27 AM
MarkX
Jul 31, 2015 07:50 AM
dmac1961
Jul 24, 2015 11:27 AM
