need help finding turbo gasket
Old May 28, 2009 | 11:11 PM
gregs's Avatar
Pull My Finger
well pretty soon im going to be installing my greddy turbo kit with the bnr upgraded turbo. im in the process getting new bolts and gaskets looks like oil drain, manifold-turbo, turbo-down pipe gaskets are the same as a t25 turbo but my question is i cant seem to find this gasket...anyone have a place where i can buy this and hopefully see it within a week or sooner...i have been told i can get it through greddy but takes a couple of months i cut a picture of the pipe i need the gasket for. btw: if i am wrong about the other gaskets please let me know
thanks
Old May 29, 2009 | 12:46 AM
WingleBeast's Avatar
HAVOC
i tried to get some replacement ones through greddy and for one reason or another it never happened.
your better off cutting your own gaskets out
Old May 29, 2009 | 12:52 AM
gregs's Avatar
Pull My Finger
i might have to go with that option...it also looks like this gasket might be the same as the evo 20g turbo by looking at the pictures
Old May 29, 2009 | 01:32 AM
chickenwafer's Avatar
Nope
That will be hard to find- 1" ID 2-bolt correct?
I have the gasket if you want it....
Old May 29, 2009 | 01:42 AM
StealthTL's Avatar
Metatron
Just buy a piece of thin 'Garlock' gasket material and trace it out.
DIY old school!
S
Old May 29, 2009 | 02:01 AM
gregs's Avatar
Pull My Finger
"old school" it is!
Old May 29, 2009 | 01:06 PM
Cattywampus's Avatar
Turbos blow!!
I did mine with high heat gasket maker. Holds like a champ.
Old Oct 5, 2009 | 02:26 PM
Eacrataes's Avatar
high heat gasket maker works for the compressor side. dont use it for the exhaust side, it turns to ash before you get the car up to operating temp >_<
Old Oct 6, 2009 | 09:44 AM
gregs's Avatar
Pull My Finger
i tried using the high heat gasket maker and it still leaks boost (but it was user error) so i think it will work just fine...i may have found a actual gasket that is always available..ill post more details once it is installed and holding pressure properly
Old Oct 6, 2009 | 12:24 PM
Turbos blow!!
I may have one for that pipe as I have an extra one. If I do I will ship it to you at no cost, except shipping, if your still having leaks.
Old Oct 6, 2009 | 03:53 PM
gregs's Avatar
Pull My Finger
here is what im working with rite now you can see the difference between my greddy outlet pipe and greddy bov gasket
Old Oct 6, 2009 | 06:18 PM
orng1's Avatar
I thought you needed the manifold to turbo gasket, that one you pictured I'd make. The other ones you need to buy. Depends where you live, I know turbo city in Anaheim has the turbo gaskets if you still need those. (714) 639-4933 turbo city, I have the number to custom turbo in Santa Fe Springs (562)944-5610. They don't always have the smaller but sometimes they do and if they are closer to you it's worth the call to avoid the drive to anaheim.
Old Oct 7, 2009 | 12:51 AM
gregs's Avatar
Pull My Finger
good info^^thanks!
Old Oct 7, 2009 | 01:18 AM
StealthTL's Avatar
Metatron
With the BNR upgrade having a larger turbo inlet, did you shave the first 'suction' pipe to fit?
.....and don't forget to trim the gasket for the same joint.
S
Old Oct 7, 2009 | 01:25 AM
gregs's Avatar
Pull My Finger
i shaved a bit off the gasket it looks like it should seal..while attempting to install my gasket i had a bolt fall into the turbocharger! i spend most of the night fishing it out without removing the turbo..ill finally put everything back together tomorrow night (btw while removing the sealant on my outlet pipe i noticed the razor did not sweep everything off im sure that flange is not smooth and might be warped
Old Oct 7, 2009 | 04:31 AM
legendkurado's Avatar
maybe a local shop can get those gaskets for you
Old Oct 7, 2009 | 10:21 AM
gregs's Avatar
Pull My Finger
^^the greddy bov gasket should work just fine with a little bit of trimming.. i also matched a tial 38mm wastegate metal crush gasket and that fits and matches the holes perfectly..i will putting the car back together tonight and hope move on with the car
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
projectr13b
Rotary Swaps
Sep 21, 2015 04:52 PM
DVerdeyen
Sep 13, 2015 11:19 AM
Rupanrx
Sep 4, 2015 06:44 AM
