Car Stalling
Old May 27, 2009 | 09:16 PM
mtourne's Avatar
Car Stalling
Hi All,
I've had some problem with my RX-8 stalling when coming to a full stop lately.
(Strangely everything started after the 60,000 miles service at Mazda...)
The spark plugs are new, I got the coils changed and I just changed the battery (group 26R it doesn't seem very powerfull)
The last thing that could be bad is the alternator. To test it I tried to start the car on the battery and remove one of the prongs.
The car stays idle and doesn't stall. But if I rev the engine and let it go back to idle it stalls.
Does that mean the alternator could be bad, should I try with a voltmeter ?
And how do you that with a voltmeter, it has to read 14v at the battery prongs when the engine is idling ?
Please help, I'm a complete noob and I've got only problems since I got this car a month ago
Old May 27, 2009 | 09:57 PM
Originally Posted by mtourne
Hi All,
Group 26R? why ? Dealership sold it to you? if yes, bring it back and say you need Group 35R.
and your issue, it sound like either bad engine, or your TB is bad.
Old May 27, 2009 | 10:11 PM
rx8cited's Avatar
Senior Member
Originally Posted by nycgps
Group 26R? why ? Dealership sold it to you? if yes, bring it back and say you need Group 35R. .....
Group 35 (no R)
Old May 27, 2009 | 10:26 PM
Originally Posted by rx8cited
Group 35 (no R)
There are Group 35 battery with Terminals in the middle of the battery.
You need 35R, so the terminals will be at the "right spot"
Old May 27, 2009 | 10:54 PM
rx8cited's Avatar
Senior Member
Do you have one in you car or pictures or can find one on the internet? Two sites I checked say group 35 for an RX8.
Old May 27, 2009 | 11:32 PM
This is common when the battery is disconnected.
The ECU is relearning.
After a few drive cycles it will be fine.
Just look at your battery.
Old May 27, 2009 | 11:34 PM
Most internet site would not tell you its a 35R, probably to avoid confusion.
Take SummitRacing for example. on the site it tells ya nothing about the 35R part. but when you get the battery, you will see it.
I did NOT get the 35R cuz my stock battery just died on me on a good morning and I need my car right away, so I ran for an Optima 35 with terminals in the middle. it doesnt fit so I have to buy another extension for the positive terminal. (negative will work, its long enough)
Old May 28, 2009 | 11:56 AM
mtourne's Avatar
I bought the battery from NAPA.
Apparently in the auto parts shops, if you tell them you have an 04 RX-8 they will give you a 26R (which was the stock I had).
For later model their database shows up with group 35 only.
I can't find any store that has the Optima 35 in the bay area, plus they will charge me a 15% restocking fee if I bring back the 26R.
Old May 28, 2009 | 12:23 PM
Yes, its hard to find Optima 35R. most shops dont even know that they existed. when you tell them you want a Group 35R, they will give you the Group 35 and say "This is the only thing that Optima makes for Group 35".
well, if it the 26 fits perfectly fine, its all good.
Just make sure it has enough CCA. 650+ preferred.
Old May 28, 2009 | 01:40 PM
mtourne's Avatar
I think it's closer to 500 CCA, would I have better starts with a 650+ CCA battery ?
And what do you guys think about the DieHard 35 Platinum that SEARS sells ? Isn't 50lbs heavy ?
Old May 28, 2009 | 02:44 PM
Charles R. Hill's Avatar
Owner of BHR
.... your TB is bad.
I agree with Jackson as Kevin (teknics) has written a bit lately about "idle air control" problems in the throttle body. This should be covered under warranty, IIRC(?).
Old May 28, 2009 | 02:57 PM
mtourne's Avatar
Hmm I'm quite a noob, what's a TB ?
Old May 28, 2009 | 03:07 PM
mtourne's Avatar
I've read teknics's thread about the IAC, in it they say that stalling might be the result of a pcm reset.
My PCM was upgraded at the same time they performed the service at Mazda, so the stalling might be normal.
I haven't experienced any stalling with the car so far with the battery replacement.
Still, how do you make sure the alternator really charges the battery ?
Old May 28, 2009 | 03:14 PM
Owner of BHR
Place a voltage tester across the battery terminals and see what your voltage is. Start the car and see if the voltage goes up. Then, turn on your headlights and a bunch of other accessories and make sure the voltage stays the same.
500 is kinda under powered. it should be ok if your local climate is not that cold. but getting something above 600+ is ideal.
That one doesnt look that bad. Sears is everywhere and 4 yrs replacement is a + for our cars. but what are you going to do with your 26 ?
So you know what TB is by now.
Your car COULD stall if you just unplug your battery, it needs to re-learn. but my old motor used to stall after I unplug my battery. and now, I just unplug my battery couple days ago, car never stalled. So in my opinion, a "good" motor shouldn't stall under any circumstances. Thats just my opinion tho.
Old May 28, 2009 | 03:38 PM
mtourne's Avatar
I still don't know what TB stands for though
Is that part dealer only ?
Old May 28, 2009 | 03:42 PM
Owner of BHR
TB= throttle body.
Old May 28, 2009 | 03:47 PM
is the silver looking thing that sits between your plastic intake and your plastic intake manifold.
Old May 28, 2009 | 04:46 PM
EDZRIDE's Avatar
2005 White GT
There is no Group 35R battery. If the terminals are in the "middle" of the battery, then it's considered a Group 75/35. See the 2nd picture, post 33 in the link below:
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/optima-red-top-batteries-151027/page2/
Old May 28, 2009 | 04:52 PM
mtourne's Avatar
I read a lot about TB / Air intake, and I'm considering mounting an oil catch can. That looks DIYable even for me
Is there a way to see if my TB is clogged with oil and how to cleaning it ? Do I need to remove it to do so ?
I haven't found any DIY forum thread about cleaning the Throttle Body.
Edit: typos
Old May 28, 2009 | 05:31 PM
EDZRIDE's Avatar
2005 White GT
Yes you need the higher amperage battery; the DieHard 35 Platinum is an excellent choice.
Old May 28, 2009 | 07:28 PM
rled's Avatar
5Picker
Your car would only stall and die if both your battery and alternator aint doing their job. If your alternator is working correctly the car will run even if your battery is bad . It just won't start back if it dies or you turn it off. Also, if your battery is fully charged, the car will run even if the alternator is not charging until the battery voltage drops below approximately 12volts.
Old May 28, 2009 | 10:12 PM
https://www.rx8club.com/showthread.php?t=151027&page=2
Thats my battery.
Maybe I got it wrong. blah.
Anyway to OP. Get something stronger.
and you cant really clean your TB. all you can do is replace it. couple hundred bux part.
Old May 28, 2009 | 10:51 PM
rx8cited's Avatar
Senior Member
Thats my battery.
So you got a back assward group 75/35 instead of a group 35 I think your confusion is that you wanted a reversed group 75/35, which would make it a group 35.
To remove any doubt out of our minds, here is the diagram for an Optima group 35 - no "terminals in the middle" like you eluded to.
Old May 29, 2009 | 07:06 AM
if I remember correctly. Someone here did get the Group 35 but it still doesnt fit. the terminal is still a bit too far and need an extension.
