Check engine light!
Old May 26, 2009 | 02:45 AM
wyldechild's Avatar
Check engine light!
Hey guys, need your help once again. So as of now, the cars been doing great. Changed the plugs last weekend and ran even better. About to do a bunch of maintenance this week to get him running like new. So my problem is... just today he started blinking the check engine light; however, it went away after a few short blinks. Then, later after work around 10pm during a 10 mile trip back home the light comes on again but stays lit this time. As far as I know, I can't tell what could be wrong from inspecting the engine so I was hoping if you guys had any advice or suggestions or should I stop being lazy and pick up some OBD software and see whats up. Everything helps so just point me in the right direction and I'd really appreciate it. Thanks a lot guys
Old May 26, 2009 | 02:47 AM
DarkLord7854's Avatar
Software Engineer
Most likely your best bet is just to go get the code read.. If I recall there's a few places that do it for free.
Old May 26, 2009 | 02:48 AM
Spinning Sushi's Avatar
I <3 Sushi
http://lmgtfy.com/?q=rx8+cel+blinks
Old May 26, 2009 | 02:58 AM
Jon316G's Avatar
Grasshopper
Yes... take it to Autozone and get the DTC code read and post what it is.
Old May 26, 2009 | 03:04 AM
Software Engineer
^ Or just Google it when you have the code
Old May 26, 2009 | 03:05 AM
I <3 Sushi
I guess I'll be nice... the blinking CEL you got are most likely due to misfires. Now, go and Google RX8+Misfires.
Old May 26, 2009 | 08:33 AM
Aseras's Avatar
check and make sure you got your plug wires on nice and tight.
Old May 26, 2009 | 09:26 AM
Vlaze's Avatar
The Angry Wheelchair
I'd just think like the Penguins in the Madagascar movies and break the light or put duct tape over it, problem solved.
Old May 26, 2009 | 11:05 AM
wyldechild's Avatar
Ya, I like the penguins solution lol but I'll take off the tire and get in there to check if I put the ignition wires on tight too. I think I'm going to go and pick up OBD CAN scan software too from OBDCOM.com just so I have it for all my cars for future reference. Also, while I have your attention... do you guys recommend the OEM ignition wires or could I just pick up some performance ones at my local shop? same goes for ignition coils? Thanks guys!
Old May 26, 2009 | 07:39 PM
Lebren's Avatar
RX8club group buy vendor
let us know what you find!
Old May 26, 2009 | 07:41 PM
I <3 Sushi
OEM is fine but if you go aftermarket, don't just pick up any random "performance" wires, some, if not most, are not suitable for the 8.
Old May 27, 2009 | 12:25 AM
wyldechild's Avatar
I was thinking picking up some NGK wires... do you have any suggestions?
Old May 27, 2009 | 12:32 AM
dozer's Avatar
on his 3rd rx8
you should go with the racing beat wires
Old May 27, 2009 | 12:33 AM
I <3 Sushi
Don't use NGK plug wires. NGK spark plugs are fine though.
Old May 27, 2009 | 12:34 AM
dozer's Avatar
on his 3rd rx8
ONLY use NGK spark plugs
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
