Test Pipe Trips Eng Light
Old May 25, 2009 | 07:21 PM
Suave177's Avatar
i've been reading a lot of the other posts related to the cel codes associated with the straight pipe. My car tripped 2 codes, p0139 and p2096. I got them read at the zone and im just curious if there are n e fixes for them besides putting the cat back on. I've checked the pipe for leaks and retightend the bolts on the pipe to make sure there were no leaks. I do have one of those o2 adapters. The eal with the o2 adapter though is that my buddy got the same one for his pipe on his 8 and his works just fine. The only difference between our cars is mines turbo and his is not. The catch though is that I was not throwing any codes before when I had the cat on. The biggest worry I have is that 2096 with the leaning out thing. My AFR still reads 14.7-14.3. Any suggestions?
Old May 25, 2009 | 08:04 PM
Suave177's Avatar
just checked for vaccum leaks and all seems to be in order. Like I said Everything can be traced back to the test pipe
Old Jun 1, 2009 | 11:07 PM
Suave177's Avatar
Old Jun 1, 2009 | 11:08 PM
yep known problem.
Get the Access Port.
Old Jun 2, 2009 | 10:28 AM
mrslysly's Avatar
07 Rx8
The CEL is because the 2nd O2 sensor is detecting that no emissions are being burnt off. Its the PCM's way of saying your cat has failed, but since you replaced it with a straight pipe, you already knew that.
Old Jun 2, 2009 | 10:54 AM
Spoolin8's Avatar
accesport or you can do the spark plug defouler trick. You screw it in to the pipe and then put the sensor in. That way the sensor is out of the direct flow and heat it will read your cat is doing its job and you wont throw a SES.
Old Mar 20, 2011 | 04:36 PM
rx85986's Avatar
any other suggestions i have defoulers in that didnt work and accessport will guarantee fix it or not im throwing p0139 and i have meagan racing downpipe and cat back no header and im throwing this code
Old Mar 20, 2011 | 06:43 PM
AP is the only way
Old Mar 20, 2011 | 07:02 PM
terch1's Avatar
Test pipe = Cel codes. Its plain and simple. Like others have said get the AP or learn to live with it.
Skyl3r
Dec 2, 2019 04:51 PM
ableobject
Mar 22, 2016 11:37 PM
MANIACman
Nov 11, 2015 10:58 PM
craig12895
Aug 25, 2015 04:50 PM
MarkX
Jul 31, 2015 07:50 AM
