Alternator life span ?
Old May 22, 2009 | 09:00 AM
Sometimes, when driving, my Navigation would just "blink" and turn itself off and restart right away, its like its not getting enough power and shuts itself down, then re-power on.
Do you guys think it might have something to do with my Optima Battery? Or Alternator ? I test it at Autozone and it saids its fine. Hmm ...
Alternator is putting out about 14.1-14.3, it jumps up and down, sometimes when I let the engine go it dips to around 12 something.
Battery was I think 13v? I forgot.
51K on original Alternator. maybe a 10 K for Optima battery ?
Old May 22, 2009 | 09:06 AM
EDZRIDE's Avatar
2005 White GT
It could be a power problem but sounds to me more like a loose connection. As to your alternator output, it will vary depending on load; you may want to check the belt tension. Assuming you replaced it when you put the new engine in, it may have stretched a bit since then. What do you mean when you say "when I let the engine go it dips to around 12 something"?
Old May 22, 2009 | 09:46 AM
Mine dips way down to 11-12 as well. I may try replacing the belt before i just replace it.
Old May 22, 2009 | 10:43 AM
51,000 on my car.
Old May 22, 2009 | 04:04 PM
Guys I found an alternator off a wrecked 06' RX8 with 6k on the odometer for dirt cheap. Let's just say it's under $50.00. What do you think?
Old May 22, 2009 | 04:05 PM
dozer's Avatar
on his 3rd rx8
id take it
Old May 22, 2009 | 04:22 PM
take it!
what have you really got to lose?! Grats on the find.
Old May 22, 2009 | 04:25 PM
Yeah I was thinking WTF, if it craps out I'll only be out a few bucks.
Old May 22, 2009 | 04:27 PM
yup.
the installation isn't all that bad, just getting the damn thing out is 'fun'.
Old May 22, 2009 | 05:50 PM
I ordered it, what the hell. Yeah I broke one of the tabs that hold the engine cover getting it out the first time but I have done it twice so a third time should be a piece of cake.
Old May 22, 2009 | 08:15 PM
I meant,
if I let my foot outa the gas pedal, the V might drop down to the 11-12 for couple of seconds. Then jumps back up to around 14. something.
The belt isnt that old. Hmm, I will check that.
Originally Posted by Jedi54
51,000 on my car.
Hmm .. Im almost 51 K, couple hundred miles more
Old May 22, 2009 | 09:28 PM
Old Rotor's Avatar
If You reseat all the connectors and fuses to your NAV I bet it'll fix it.
Old May 22, 2009 | 09:35 PM
I'll try that next week.
but I wouldnt be surprise if the thing fails (Alternator)
Old May 23, 2009 | 09:57 AM
Socket7's Avatar
ಠ_ಠ
Doesn't the alternator have some sort of current or voltage regulator? That could be the culprit as well....
Old May 23, 2009 | 11:26 AM
that's what I believe kicked the bucket on my alternator. Damn regulator is $186
Old May 23, 2009 | 01:12 PM
elysium19's Avatar
seems much more likely to be a loose connection...
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
OnebaddRx8
Aug 25, 2019 11:34 PM
vapor2
Jul 9, 2016 07:35 AM
Rx8 VA Guy
Jun 4, 2016 12:42 AM
