Radiator removal?
Old May 20, 2009 | 05:14 PM
canaryrx8's Avatar
Radiator removal?
So has anyone here replaced their radiator themselves? Any pointers? does it come out from the top or from underneath the car? I'm also replacing my thermostat while it's all apart so any help/advice with that would be most appreciated!
Thanks!!!
Old May 20, 2009 | 05:17 PM
quazmosis's Avatar
Chode
I just did the thermostat. That's pretty easy. Not sure on the radiator though.
Old May 20, 2009 | 05:18 PM
Spinning Sushi's Avatar
I <3 Sushi
Best way to remove the radiator is to remove the undertray/rock guard, drain it, and unbolt. Everything is done underneath the car.
Old May 20, 2009 | 05:19 PM
https://www.rx8club.com/showthread.p...place+radiator
Old May 20, 2009 | 05:26 PM
quazmosis's Avatar
Chode
http://www.myrotarycar.com/portal/fo...3le/index.html
I used this link in finding and replacing the thermostat. That's pretty much making sure that little notch/indentation matches up that's about it.
Old May 20, 2009 | 05:27 PM
quazmosis's Avatar
Chode
When refilling make sure you get all the air out of the system. That's what I'm dealing with now.
Old May 20, 2009 | 05:42 PM
canaryrx8's Avatar
I did a search, must have typed in the wrong phrase
Thanks for the help all, going to be fun getting underneath the car
Old May 20, 2009 | 08:21 PM
bRRRRWWWAaaarRRRR
ANY ? let me know
Old May 21, 2009 | 12:02 AM
it really sucks on jack stands..
Old May 21, 2009 | 08:55 AM
staticlag's Avatar
The Professor
1. drain ccolant & remove undertray via my DIY https://www.rx8club.com/series-i-do-yourself-forum-73/diy-coolant-change-100164/
2. remove airbox and battery tray for access to the upper radiator hose and access to disconnect the fan connectors.
3. unscrew two bolts on the upper overflow tank.
4. unclip 2 upper & 1 lower radiator hoses. Disconnect all fan connectors, the fan assembly on the back will come off as part of the radiator also.
5. its off, unbolt two upper bolts on radiator and slide it up and then out underneath the car. careful the fan makes it heavy and its fragile.
6. replace.
Old Jun 8, 2010 | 10:22 PM
RINO2085's Avatar
does any one have pics of doin this? if not I will do it and put them on here if yall want just let me know
Old Jun 10, 2010 | 01:48 PM
Sorry. U are 3 years late
Old Sep 8, 2014 | 09:15 PM
JHernandez's Avatar
And how do you make sure all.the air is out
Old Sep 8, 2014 | 09:24 PM
Rtfm
Old Sep 9, 2014 | 08:45 PM
JHernandez's Avatar
Anyone Please Help
Does anyone have the knowledge or done a radiator change out +cooling fans on their RX8?????
RIWWP's Avatar
Yes, lots of people.
Old Feb 2, 2015 | 09:48 PM
stepheng273's Avatar
Which would be faster? Taking the radiator out from the top or bottom? I need to replace mine.
Old Feb 2, 2015 | 10:13 PM
logalinipoo's Avatar
Driving my unreliable rx8
Bottom
Old Feb 2, 2015 | 10:44 PM
Legot's Avatar
Scrappy
Originally Posted by logalinipoo
Bottom
Definately.
olyrx7
Oct 26, 2015 09:23 AM
Racingjunkie
Sep 29, 2015 05:05 PM
xAgyex
Sep 28, 2015 08:54 AM
Learners_Permit
Sep 27, 2015 07:38 PM
