Unbolting the knock sensor
Old May 20, 2009 | 12:06 PM
kennyfrc1's Avatar
It appears that our knock sensor is very conservative and sometimes determines normal engine noise and vibration as knock. The ECU then pulls timing which results in power loss. If you are not FI and always run premium fuel knock should not be an issue and we may gain power from unbolting it. On the other hand, if you were to experience knock I doubt it would hurt an NA motor.
Here are some quotes from Racing Beat's Site:
“We have also tested the knock sensor system and found that though it is good, it can cause minor problems. The sensor seems to detect normal engine vibrations as “knock” (pre-ignition), and because if this, the ECU retards the timing. Unbolting the knock sensor from the #2 rotor housing (do not disconnect it electronically - this will cause an ECU fault and retard the timing.) usually adds a small amount of power (often 1+HP) by eliminating the random, unnecessary retarding of ignition. Of course, if the engine should experience knock, your unbolted sensor will never know it- but cars ran for many years without these sensors and survived!”
Knock Sensor – “The reason for unbolting the knock sensor is that our testing has shown that the ECU sometimes randomly retards the ignition even when there is no actual detonation occurring. (Detonation - pre-ignition combustion of the compressed intake charge.) The difference is only 1-2 HP, but this is more than the differences we are looking for. We obtain more consistent test results by unbolting the sensor (but leaving it connected electronically so that it doesn't cause a fault in the ECU); thereby preventing it from feeling the vibration it mistakenly thought was detonation.”
Thoughts?
Old May 20, 2009 | 01:34 PM
kersh4w's Avatar
Hit & Run Magnet
im remembering the thread where someone was looking for an "aftermarket kock sensor." we all had a good laugh about that.
Old May 24, 2009 | 12:58 AM
you better be using high octane fuel, otherwise one series of knocks and it's goodbye apex seals
Old May 24, 2009 | 01:08 AM
dondo's Avatar
100% baller (finally!)
this is what some guys at our dyno day were saying might be happening to my car. it was pulling like 20-25hp less (142-144) than similarly configured cars (165) and then ran once much closer to the other guys (155). This was out of 6 pulls. I have new plugs, ignition coils, wires, and good compression.
do you think this could be part of the problem or is there something else i should look into?
Old May 24, 2009 | 01:14 AM
Easy_E1's Avatar
Were these piston engine owners? The knock sensor is so bad on our car that is pretty much useless. You'd have to hit it with a hammer to get a reading.
Just to make you feel good,, you have less HP then my 4 Port AT.
I would say that the dyno may not be calibrated correctly.
Old May 24, 2009 | 01:16 AM
dondo's Avatar
nah, 8s. that's what's weird. even an 8 in stock trim did better than mine: 166...
Old May 24, 2009 | 01:20 AM
Easy_E1's Avatar
That's till pretty low on the scale. I've seen mine range about 25 whp on different dynos on different days.
I've also seen a stock AT do 155 whp. While mine did 145 with intake exhaust and BHR coils and an Accessport. Some 8's just have more HP. I don't know why.
Try some injector cleaner in it. Se if that helps.
Old May 24, 2009 | 01:24 AM
dondo's Avatar
mine was well below the others and i have intake/catback exhaust/ap/bhr ignition..
i suppose this fails w/o pics though.. i'll try to scan the graphs.
Old May 24, 2009 | 01:33 AM
Easy_E1's Avatar
Has MM done the full range of tuning on your AP? Or are you guy's still working on it?
Old May 24, 2009 | 01:45 AM
dondo's Avatar
we did the first part on the dyno in seattle and he told me the coils were bad so i got the bhr ones and recently got those working well so i put it on the dyno again. my plan is to datalog again now and send that in for another map to see if it helps at all.
i can't scan now, scanner's not working, so i'll get them up tomorrow.
Old May 24, 2009 | 02:15 AM
Easy_E1's Avatar
I'll remind him tomorrow when he gets back in town. Just do the 11 Deadly questions and submit the logs.
I think you'll have better results when the car has the proper tune on it. I hope.
Old May 24, 2009 | 10:25 AM
pdxhak's Avatar
Official Post Whore
Dondo's numbers are from a Mustang dyno. We had 3 8's dyno back to back to back with my car being the 3rd car. I pulled 163 with new OE coils and plugs. I also have RB intake and Corksport exhaust. What is a bit interesting is Dondo's graph. He peaked earlier than the 3 8s that pulled in the 160s where others still climbed.
Note: I believe we had 6 8s get on the dyno. 3 in the 160s, 1 157, 2 in the 140s.
Old May 24, 2009 | 12:18 PM
Easy_E1's Avatar
That is still some low numbers for all the cars. I suppose it's just the Mustang dyno.
But I like it. It means there are 6 MT RX8's out there with less HP than my 4 Port AT.
Old May 24, 2009 | 12:36 PM
pdxhak's Avatar
Official Post Whore
haha...what are you mods? If you are spraying or FI then it does not count
Old May 24, 2009 | 01:39 PM
JantzenRX-8's Avatar
I can't remember what Dondo's graph looked like but we have similar mods and similar results.
Here is mine for comparison.
Old May 24, 2009 | 01:46 PM
^ your curve goes dead at around 7000, looks like the APV may not be opening
Old May 24, 2009 | 01:56 PM
Would that throw a CEL?
Old May 24, 2009 | 02:04 PM
pdxhak's Avatar
Official Post Whore
Dondo's graph did that as well. The other 8s keep climbing where theirs start to fall off.
Old May 24, 2009 | 05:33 PM
dondo's Avatar
here are mine:
SKMBT_C35309052414060.pdf
Old May 24, 2009 | 05:55 PM
dondo's Avatar
submitted today.
thanks!
Old May 25, 2009 | 02:20 PM
only if it's stuck in the open position
Old May 25, 2009 | 07:22 PM
But if it completely stops operating it think's everything is A-OK? That seems odd.
I'll have to check to see if the motor that controls the APV is operating correctly.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
