Loosing power at high rpms
Old May 17, 2009 | 01:14 PM
Red-x8's Avatar
Hi Guys,
I'll try to do my best to explain my problem and sorry for my average English since this is not my first language. I searched and found similar problems but still want your opinion. My 8 is an 07 with 9 000 km on it and recently I noticed something and the problem seems to grow by time. I first noticed irregular accelerations , by that I mean the car was still accelerating but not smoothly, specially in 2nd gear. 2 days ago it was very very rainy and the car was struggling a bit more.. and a bit later when I was trying to accelerate ( gas pedal on the floor ) the car was accelerating just a little bit ( gained like 3 kmh in 10 seconds , was in 5th gear at something like 115 kph which is around 65mph ) Right after this I tried a test so i shifted in 6th and tried to accelerate to reach a faster speed , the car was stuck at 139kmh.. very weird. Like I said it was very rainy that day so since I have the car since 3 months and never drove it under heavy rain I tought that maybe the air filter ( I have a MS CAI ) was wet and was the reason why the engine was struggling ( well it made sence in my mind lol ) So Today the rain is gone and I noticed a lost of power at higher rpms ( higher than 4000 ) when I accelerate the car NORMALLY accelerate but right after 4k the engine gradually run louder ( CAI i guess ) BUT even the RPM seems to go up very slowly , same for the speed.. So its like the engine SOUNDS like running at higher rpm but is not .. and not generating hps.. so heres my little story and why i need some advices ..
heres a few questions and facts because even if i start a new thread I search and found similar problems , not exaclty like mine tho.
1-Can it by my wet CAI?
2-If not what may be the problem Cat?
3-Is it on warrenty?
about my car :
-Like I said I have the MS CAI
-The car is only 9 000 km ( less than 6 000 miles )
-I use Premix
-Already Cheked oil , it was fine
-Maybe its me but the engine seems to scream louder than it was specially after 4k rpm
-Car was flooded once .. by the dealership they replaced the plugs if im correct.
-The Idle is perfectly smooth
-I dont have a CEL I had one one and it was gone the day after
thanks in advance for your help
Old May 17, 2009 | 02:16 PM
8rocks's Avatar
Wet CAI - very likely culprit
Cat - with such low mileage, I doubt it's the Cat but since you know for a fact the dealer had flooded the car, it would be worth checking.
A 2007 with such low mileage should definitely be under warranty. Take it in and get it diagnosed. Be careful how you present the issues to them. Typically problems occurring at those speeds (140 km/hr) are not taken seriously by dealerships with the excuse that they can't be replicated. Think your presentation through before you take it in.
And please keep us updated.
Old May 17, 2009 | 02:18 PM
Ever Hernandez's Avatar
Rx8_4eVeR
Sounds too early for plugs, cables and coils so clean your MAF sensor maybe that would help, clogged cat maybe
Old May 17, 2009 | 02:19 PM
Winning 8's Avatar
Hot Pit
sound like the cat..
Old May 17, 2009 | 02:22 PM
dmp's Avatar
dmp
RX8 and a Truk....
Bad Cat. Lock it up. Put it on the board. For sure.
My first cat went about 15k miles: https://www.rx8club.com/showthread.p...&highlight=cat
Second Cat went about 25k miles: https://www.rx8club.com/showthread.p...ghlight=dealer
Old May 17, 2009 | 03:04 PM
Red-x8's Avatar
Ok I dont mind cleaning it is it difficult? any input on how to clean it would be appreciated
edit : nevermind just found the DIY
Old May 17, 2009 | 04:22 PM
Red-x8's Avatar
Well afting inspecting my air filter more closely I noticed that it still wet even after 2 days .. so maybe Its not my Cat after all ..
Old May 18, 2009 | 01:19 PM
Red-x8's Avatar
Well After drying my CAI filter I still have the same problem plus I got a CEL today .. going to the stealership tomorow morning
Old May 24, 2009 | 08:39 PM
Red-x8's Avatar
Well since my appoint ment in only in 4 days I managed the get the CEL codes they are p0411 and p0410 .. Aanyone have a clue?
Old May 28, 2009 | 03:57 PM
Red-x8's Avatar
ok problem solved
Went to my local dealership and they said I was the CAT , they sais the car was probably flooded once and it may caused the problem ( Maybe the previous owner because I only have the car since a few months .. and who knows maybe the dealer where I bought the car .. ) Anyway the replaced the CAT since its still un warranty
Thanks for all your help
Old May 28, 2009 | 04:06 PM
Roariee's Avatar
It was this big! No lie!
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
cushing75
Nov 12, 2018 12:46 PM
uZu
Dec 30, 2015 12:35 PM
vetteor8
Jul 25, 2015 11:43 AM
