Front Rotor Screws
Old May 16, 2009 | 11:38 PM
thawk97's Avatar
...pondering...
Front Rotor Screws
So, I haven't seen a thread dedicated to this (though the topic is in some other threads).
I changed my rotors today and, like many before me, struggled to get the screws out of the front rotors. My impact wrench couldn't get them, I broke a bit in it, and then stripped them out using a breaker bar. SO, I had to drill them out - wasn't a big deal.
The question is - do I need to go get a set of new ones from the dealer and put them back in? I can't really think of what purpose they serve as they don't exist on the rears and the 5 lugs are holding the rotor in place. Can anyone please tell me if they're necessary and if not, then why they're on the car?
Just need to know if I should go buy them and put them in.
Old May 16, 2009 | 11:42 PM
nuke0907's Avatar
Never Blend In
they are there to hold the rotor on when you take your wheels off. you are right the lugnuts will hold it in place. might be a good idea to get new ones anyways. wouldn't be too fun to take your wheel off and see your rotor crash to the ground and get damaged.
Old May 16, 2009 | 11:46 PM
dozer's Avatar
on his 3rd rx8
How would the rotors fall to the ground when the brake calipers are holding it in place? DUH!
Old May 16, 2009 | 11:48 PM
dozer's Avatar
on his 3rd rx8
Also, the screws are there for manufacturing purposes, you do not need them.
Old May 17, 2009 | 04:35 AM
Jon316G's Avatar
Grasshopper
Correct.
And if you have trouble getting those screws out, give it a little heat and it'll easily turn.
Old May 17, 2009 | 06:43 AM
invasion08's Avatar
Or if you have trouble getting the screws out use a Craftsman Impact Driver.
http://www.sears.com/shc/s/p_10153_12605_00947641000P
Old May 17, 2009 | 06:55 AM
Optical TDI's Avatar
Bottom line: you don't need to buy new ones. I don't use mine since they are PITA.
Old May 17, 2009 | 06:56 AM
Huey52's Avatar
Registered Zoom Zoomer
A hand impact driver will do the trick. More control (less chance of breakage) than a powered driver.
WD-40 or similar penetrating fluid prior will help as well.
http://www.harborfreight.com/cpi/cta...emnumber=93481
Old May 17, 2009 | 07:12 AM
Jon316G's Avatar
Grasshopper
That'll work too. I first used that on my rotors.
But honestly, I was able to unscrew the bolts with a basic screwdriver after applying heat on another local's car.
It was easier than hitting it with an impact driver... but we both had our cars out during a few winters so our bolts were probably worse that others.
Old May 17, 2009 | 11:02 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah a little wd-40 and impact....but yo don't need them the caliper holds the rotor on when u take the wheel off
Old May 17, 2009 | 11:10 AM
04RX8man's Avatar
yes wd-40 and impact driver should take care of it and u don't need to replace...just basically there for the factory so when they are assembling the car they don't have to worry aqbout the rotors coming off....
RXFEVER
Sep 11, 2016 02:51 PM
jackslao
Sep 8, 2015 01:50 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
rxwilly8
Sep 2, 2015 02:42 PM
