Will any conventional 5w-20 do?
Old May 15, 2009 | 05:11 PM
05TouringRX8's Avatar
I don't want to start an oil discussion. So, let's just assume I'm going to use factory recommended weighted oil in my 05 '8. So far the oil has been changed regularly by a dealer but I don't know what brand they used. There's no dealer where I live but I have a shop here that I trust. Should I let them use whatever 5w-20 they want to put in it or should I specifify? I don't know what they would normally use for that weight but, in my truck and Jeep they always put Shell 10w-30.
Old May 15, 2009 | 05:12 PM
theoretically any oil should do. I'm partial to Castrol GTX
invasion08's Avatar
any 5w20 will do. I just prefer castrol gtx.
Old May 15, 2009 | 05:13 PM
dozer's Avatar
on his 3rd rx8
dont use pennzoil they have a piston on their bottles ...go castrol gtx
Old May 15, 2009 | 05:16 PM
I understand I'll need to keep some extra oil to add when it gets low between changes. Would it have to be the same brand they use or just the same weight, etc? If they have Castrol GTX, I'll request that.
Old May 15, 2009 | 05:22 PM
invasion08's Avatar
You can use a different brand of oil then what the shop used, just use the same weight.
Old May 15, 2009 | 05:24 PM
as long as the weight is the same, you should be fine.
I usually just take 4 quarts with me if I'm having someone else change the oil. (comes out cheaper that way)
Old May 15, 2009 | 05:32 PM
Well I'm taking my truck in first to get it serviced and have the EGR valve replaced. Last week when I went to look at the '8, the check engine light came on and I found the code to mean the EGR sensor had thrown the code. I reset it and it came on again today when we went to pick up the car. So, I'll discuss with them the oil and see what they have or recommend. If they are open to me bringing my own oil, I'll stop buy and get it before I take the car in.
What about filters? Should I be specific about that too?
Old May 15, 2009 | 05:41 PM
05rx8mazda's Avatar
B.I.G
I like valvoline.. with a k&n filter or oem mazda filter.... or mobil oil filter.. right now i am using royal purple.. its been great for the past 30k miles
Old May 15, 2009 | 05:49 PM
I've never seen a shop have issues with a customer bringing their own oil or filters. (as long as the oil bottles are unopened)
as for filters, check out Atkins Rotary. http://www.atkinsrotary.com/store/pr...cat=648&page=1
(those are OE quality filters)
Old May 15, 2009 | 06:03 PM
The Drunk IT Guy's Avatar
I just shat myself
I've always used Valvoline because that's the only 5w-20 oil at Walmart haha. My car still runs.
Old May 15, 2009 | 06:13 PM
04RX8man's Avatar
Rotary Powered Countryboy
I have used valvoline,castrol, and pennzoil...i'm partial to castrol....and i've used 5w20, 5w30, and 10w30.....so anyway anything is fine just decide on the weight you want....I use a FRAM filter(I know i'll get flamed for that one probably) but i've never had a problem with them...and when i'm at good old walmart i can get the filter there too!
Old May 15, 2009 | 06:18 PM
exsequor's Avatar
wipe me down
Great minds think alike.
Old May 15, 2009 | 06:32 PM
ZoomZoomH's Avatar
Mulligan User
Motorcraft 5w-20
<-- has 91,000+ miles on original motor
Old May 15, 2009 | 09:08 PM
Star Mazda Atlantic's Avatar
Castrol GTX is about the only thing I can find at retail that actually matches what it says in the manual.
Old May 15, 2009 | 10:37 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
I don't think there'd be a problem mixing something like 5W-20 and 5W-30. It'd end up like 5W-25 so to speak.
Old May 15, 2009 | 10:52 PM
SLWASFK's Avatar
Any dino juice will do, but I highly recommend Idemitsu.
However, I don't know that Idemitsu makes a 5w-20 formula.
Old May 15, 2009 | 11:42 PM
heyguy22's Avatar
wolfs head ftw
Old May 16, 2009 | 01:10 AM
ecsw's Avatar
any disadvantage if use 5w-30?
Old May 16, 2009 | 02:26 AM
cjkim's Avatar
^noob
only advantages
Old May 16, 2009 | 02:29 AM
SLWASFK's Avatar
^--The 8 is my first non-turbo rotary. I know 20w-50 would be like molasses in this engine, but what is the best middle ground weight to run in the MSP? 5w-30? 10w-30?
Old May 16, 2009 | 02:36 AM
cjkim's Avatar
^noob
5w30 is popular as its what the rest of the world uses in the 8
i'm thinking of switching to 10w30 soon since i never see colder climates though
Old May 16, 2009 | 09:10 AM
As I said, I didn't want to start an oil discussion. However, I was doing random searches on google on this car before I bought it. I remember seeing a thread somewhere where a guy was ranting about there being no reason to use anything but 5w-30 in this engine as that is what the manufacturer recommends in every other country this car is sold except for the USA. I'm taking a stab but wondering if it has something to do with the EPA and exhaust regulations as far as why they recommend 5w-20 here? Either that or something to do with temperature differences here vs. other countries? As you can tell by this thread, I'm not an oil expert. If I can be convinced to go with something other than 5w-20, I will do it. But, can they reject any warranty claims on the motor if they find you've used something other than conventional 5w-20?
Old May 16, 2009 | 10:11 AM
JinDesu's Avatar
went back to srsly broke
I believe they really can't check if it's 5W-20 or 5W-30. As long as you don't tell them, they won't know.
And honestly, don't tell them. I'm going to be using 5W-30 pretty soon, and sticking to that all year, if not higher for the summer months.
Old May 16, 2009 | 10:29 AM
SLWASFK's Avatar
Let me know how the 10w30 works out for you. You'll definitely want to let the car get up to operating temperature before driving if you do switch to a heavier weight like that.
I'll eagerly await your report, it's killing me that Idemitsu doesn't make a 5w-20 oil.
