Helppppp!!!
Old May 14, 2009 | 07:14 PM
Shawna_'s Avatar
Helppppp!!!
I have a 2006 with 21660 miles on it. Today as i was driving it seems to have lost mearly all power? Bearly can climb hills and with it floored in is no where near it's normal power house? I am baffled and REALLY worried? it is a 6 speed manuel. Has anyone else had this issue? I can't get it in the shop till tue.
Old May 14, 2009 | 07:22 PM
myriadshalaks's Avatar
rot8ing
check your spark plugs.
Old May 14, 2009 | 07:23 PM
Jon316G's Avatar
Grasshopper
+1
Also make sure the plug wires are secure. They've been known to come loose.
Then possibly a clogged cat.
Have you received a CEL yet?
Old May 14, 2009 | 07:27 PM
shaunv74's Avatar
Power!!
You are still in bumper to bumper warranty. Bring it to the Dealer and tell them to fix it ASAP for free.
Old May 14, 2009 | 11:10 PM
RotoRocket's Avatar
Freely Radical
Yes.
B2B warranty for 4 years/50,000 miles
Powertrain warranty for 5 years/60,000 miles
Rotary warranty for 8 years/100,000 miles
Old May 15, 2009 | 11:39 AM
snicklefritz's Avatar
Definately check your spark plugs as mentioned above. I've had two incidents like this however, and it was the CAT that was clogged... (check your air filter while you're at it).
Old May 15, 2009 | 11:43 AM
Forgot to add, are you experiencing any excessive loss of fuel?
Old May 15, 2009 | 01:06 PM
zoom44's Avatar
clutch slip?
Old May 15, 2009 | 01:07 PM
zoom44's Avatar
where located?
Old May 15, 2009 | 04:37 PM
Shawna_'s Avatar
UPDATE: Okay so apperantly there is a recall right now. There seems to be an issue with the computer. I will update you with more details after thu.
Old May 15, 2009 | 04:48 PM
shaunv74's Avatar
Power!!
Make sure they check your Cat. Converter, coils, wires, plugs before they try to replace your motor under the recall.
Old May 15, 2009 | 04:53 PM
rot8ing
lack of the reflash, tsb msp16, for the ecu isn't causing your problem.
the reflash addresses issues with rough idle.
calm down. there's something minor wrong with your car.
i would doubt it's the cat given the low miles, but maybe, i guess.
still think it's your plugs. have you checked them yet? it's real easy to do.
Old May 15, 2009 | 04:55 PM
Good thing you still have warranty. I'm actually hoping mine goes again before 100k.
Rotary-RX8
Feb 25, 2011 03:40 PM
GeTcRuNk
Oct 4, 2005 11:19 AM
