Problem Removing: Center 2 Lights - Were the Sunglasses Storage/Sunroof Switches are
The 2 Lights located above your head. Were you can put sunglasses and open your sunroof. Im trying to get that out so i can replace the current lights but im having such a bitch of a time trying to get it off... I can remove the screws and unlock the 3 safety clips which would be facing the windshield to give you an idea... THats as far as i can get... and im scared if i pull really hard ill break the plastic or something
Has anybody done this before?? Any suggestions??
The devil made me do it
Yea...I did it and went through the same things you are. There are two metal clips on the sides that are holding it in. Basically it was just keep pulling and eventually it came out.
Make sure you use a screwdriver to slip the bottom of the clips over the headliner before you begin pulling. Otherwise you'll tear up the headliner and probably break the metal clips as well. Not good.
xAgyex
Jun 3, 2026 03:47 PM
MarkX
Jul 31, 2015 07:50 AM
