View Full Version : something wrong in my car
jay_ar1010
05-07-2009, 03:30 PM
my car just keep died in the freeway and i dont know what's the problom...i just change my spark plugs,oil change....but just the engine is kinda not in a good sound ..its like something wrong....but i dont want to touch my engine right now....coz i might spend money again...and im going home for vacation... and i need money right now...maybe i'll try to tune my car when i go back....hepl guys....
philipchan
05-07-2009, 04:02 PM
The warranty should cover, bring it to the dealership!
Razz1
05-07-2009, 11:41 PM
Plugs could be loose or the wires. Check the wires.
How old is the battery?
Did you disconnect the battery when you serviced?
List year and miles
Franky A
05-08-2009, 12:18 AM
Sounds like it's a battery problem. How old is the car?
scremn8
05-08-2009, 07:06 AM
my spark plug wires came loose on the fwy once.
went dead just as i was changing fwy's..
check wires then battery, then tow to dealer.
if it goes to dealer make sure you have it on
a flat bed tow truck...
Atilla
05-08-2009, 10:50 AM
The sound coming from your engine - is it a knocking sound?? :scared:
bao0518
05-08-2009, 11:49 AM
if you have a after market intake, check that. If there is no air or not enough air going into the engine..it will turn off
Jedi54
05-08-2009, 11:52 AM
check out the West Coast peeps coming to the rescue!
some great suggestions here.
- Has your car been driving fine prior to this?
- Definitely check your battery cables
- The spark plug cables have been known to come loose.
- If you disconnected the battery cable, could be the all the fuel trims were reset so the car is trying to settle them. (this can lead to a rough idle for a few drive cycles)
- Did you double check the MAF sensor connection?
- How long since you cleaned the MAF?
- Aftermarket intake?
One last suggestion: double check to make sure the coils are going to the appropriate plugs. I know this sounds stupid but sometimes the simplest thing is what causes the issue.
Atilla
05-08-2009, 11:53 AM
Bao puts up a good point - If the maf is loose or not secured, the motor will shut off. This happened to me once when i replaced my intake box. Scared the shit outta me...
Razz1
05-08-2009, 08:40 PM
Maybe it morphing into a Camary.......
Spinning Sushi
05-12-2009, 01:45 AM
Camry's (Camries?) are awesome!
jay_ar1010
05-12-2009, 08:10 AM
engine light on now.....i fill like there's really something going on my car...
remixlp
06-04-2009, 03:21 PM
Get a compression check. I have the same issue right now and about 4 error codes. I cant figure it out.
SiLVeRE8
06-04-2009, 05:28 PM
were there any popping sound coming from speakers when the car was dying out?
