View Full Version : car has power and is turning over strong...but wont start
vglnte1
05-05-2009, 06:21 PM
almost like the fuel pump is out?
any ideas?
invasion08
05-05-2009, 06:32 PM
Going to need more info about the car: Year, Mileage, and anything else that will help us help you
vglnte1
05-05-2009, 08:18 PM
2005 6 speed. about 30k miles
no mods
Jon316G
05-05-2009, 08:20 PM
Engine Flooded?
vglnte1
05-05-2009, 08:23 PM
i found this....true?>
http://www.fixya.com/cars/t1422869-mazda_2005_rx_8_wont_start_ran
vglnte1
05-05-2009, 08:24 PM
Engine Flooded?
i never pumped the gas pedal, and as soon as i started to crank it it did this...i know nothing of rotary motors....i have only worked on GM V8's.
Jon316G
05-05-2009, 08:28 PM
You don't pump the pedal, you hold it down while starting.
This keeps it from injecting more fuel into the chambers.
Don't do it for more than 10 seconds.
Some have had better luck removing the spark plugs and then starting it with the gas pedal held down (with a rag nearby to catch the fluids).
There are other methods to help "de-flood" so you might want to search for that if this doesn't turn it over.
vglnte1
05-05-2009, 08:44 PM
lost my book for the car:icon_no2:
can someone post a pic of which one the ful pump fuse is?
Jon316G
05-05-2009, 08:52 PM
You do know that the panel cover has the layout ;)
Jon316G
05-05-2009, 08:53 PM
You can also download the owner's manual from MazdaUSA
04RX8man
05-05-2009, 09:37 PM
use the search function!!!!! remove plugs....take fuel pump fuse out....crank car 10 sec at a time till no fluid comes out then install plugs and fuse then it should fire up...
vglnte1
05-05-2009, 09:54 PM
i removed the plugs....well the 2 i could get to....and there was no fluid in there....
so im supposed to try to start with no fuse or plug? what will that accomplish?
Alexb
05-05-2009, 10:40 PM
Isn't it possible the plugs are just dead altogether?
vglnte1
05-05-2009, 11:27 PM
no idea. i did the fuel fuse trick. i removed all 4 and did the whole service buliten and nothing....fuck this car
Razz1
05-06-2009, 12:03 PM
Please update your profile so we know where you live.
Your local club members should be able to help you out.
Are you getting any spark at all?
Have you ever changed the plugs?
Its time for a tune up at 30k per manual, so don't say fuck the car when you don't follow maintence guide lines.
We are here to help.
Edit: So your first post says you bought a 2006 now you say its a 2005. So what is it? Post a picture of your car.
Here's a link to a shop manual for future reference.
http://foxed.ca/rx7manual/2003mazdarx8/
Huey52
05-06-2009, 12:35 PM
We understand your frustration. Any car can be flooded, but the rotary is a bit more susceptable.
Taking out the plugs and removing the fuel pump fuse allows you to crank the engine, to drive out excess fuel/vapor, without introducing more fuel which would be self-defeating.
Once you're assured you're 'dry', reinstall the plugs and fuse and attempt start.
Alternatively, if you have a manual transmission, you can have someone push/pull you with ignition on and drop it into gear to start.
btw: if you have an '05 built before circa January '05 you may need the upgraded starter and battery (if you have a Panasonic battery you probably have the older starter; if an Interstate probably the newer).
White_Shadows
05-06-2009, 12:59 PM
Question of the century. How do you start your car every time you go to drive it? Do you just start and go? Or do you warm it up every single time you start it? If not, enjoy the flood and there are alot of stickes and tips and tricks. When all else fails call for a tow to local shop. Don't hate the car just for not understanding it. A bit more to it then an old 350.
Oh and do you drive it like you stole it? If not compression check time. No worries though you are still under warranty, but read read read. This is not a push button and go car.
Nubo
05-06-2009, 02:40 PM
Let's not muddy the water with misinformation. Start and go is perfectly fine unless extremely cold weather.
Better to get back to basics. Spark, Fuel, Air, Compression. Same as any other car.
