problem with greddy turbo kit.
Old May 3, 2009 | 12:36 PM
CraigRX8's Avatar
CraigRX8
Finished the install during the week. car turned on but stalled straight away, i looked at the map and it had alot of zero values. I think maybe the engine flooded at this point. so i uploaded new base map, went to crank and nothing, then i noticed a flashing red light which had never happened before this was on the emanage unite. so i took out those controls and then tried to start the car running an oem map thinking the car might run but not be driven anywhere but it wouldnt ignitie either. so i took the spark plugs out, dried them, cranked the engine with fuel pump out and still nothing. any ideas
Old May 3, 2009 | 12:48 PM
shazy's Avatar
Get a couple of friends and try to push start the car.
Old May 3, 2009 | 02:54 PM
Kane's Avatar
Senior Member
When you turned it over with the plugs out - did you unplug the ESS sensor?
Also - did you have fuel coming out of the plug holes?
ed0128
Sep 9, 2015 04:50 PM
mattymack
Sep 6, 2015 10:33 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Octomus
Sep 3, 2015 11:40 AM
