Help - I took my caliper off to paint them.
Old May 1, 2009 | 07:47 PM
CandiApple-RX8's Avatar
Unhappy Help - I took my caliper off to paint them.
I took my front wheel off to paint my caliper and forgot how to put the caliper back together. I need some assist on putting everything back together. Please help if you can.
https://www.rx8club.com/images/smili...cons/icon9.gif
Old May 1, 2009 | 08:32 PM
myriadshalaks's Avatar
rot8ing
post some pics. ask more specific questions.
Old May 1, 2009 | 08:39 PM
Socket7's Avatar
ಠ_ಠ
Push the piston back into the caliper with your hand, put the pads back into it, slide it over the rotor and bolt it down. Use the caliper on the other front wheel as a reference. (Do not disassemble the other caliper until you have successfully put the first one back together, so you have a reference when you forget how to put the other one back together.)
http://isomerica.net/~fluffy/Ren/RX8%20FSM/ Factory service manual is available here. it should detail how the caliper goes together as well.
Old May 1, 2009 | 09:48 PM
Mu ha ha... pictures don't show.
You need a C Clamp for the front calipers and a needle nose pliers for the rear.
Go to DIY for brake chane.
Old May 2, 2009 | 07:02 AM
Thank you all so much for responding. I appreciate all the feedback. I panicked because I am new at this and was trying something very different for me. I did get the caliper back on but now the brake light will not go off. I think I need to bleed the brake line. Thank God I only did one wheel at a time so I can isolate the problem. I appreciate the link to other sites that will be very helpful for me. I am deterimine to finish this project myself. You guys understand how we RX8 Lovers feel about our Babies. Thanks again I really appreciate the responses.
Old May 3, 2009 | 10:01 AM
04RX8man's Avatar
Rotary Powered Countryboy
yeah if u had the caliper off u MUST bleed the brakes
Old May 3, 2009 | 08:07 PM
ZmFnZm's Avatar
you have to bleed the whole system, last thing you want is a random air bubble in your brake lines
Old May 3, 2009 | 08:27 PM
Alexb's Avatar
desperately needs a drop
Speaking of. Anyone know of a good writeup on how to bleed brakes?
Old May 3, 2009 | 10:40 PM
kersh4w's Avatar
Hit & Run Magnet
just change your brake fluid.
that pumps all old fluid and bubbles out.
Old May 3, 2009 | 11:27 PM
shazy's Avatar
What happens if there is an air bubble? (I know dumb question, but just want to know)
Old May 4, 2009 | 06:56 AM
stayfrosty's Avatar
air compresses, brake fluid doesn't your foot would go to the floor when you hit the brakes and you wouldn't stop
Old May 4, 2009 | 08:37 AM
Huey52's Avatar
Registered Zoom Zoomer
Yep, and you can use an inexpensive gravity feed tool rather than an expensive pump:
http://www.harborfreight.com/cpi/cta...emnumber=37201
Additionally, you may want to consider installing speedbleeders since you've already got the wheels off and are working on the brakes:
http://www.russellperformance.com/mc/speed/import.shtml
Old May 4, 2009 | 05:28 PM
Thumbs up Bleeding the brakes
After trial and error, I was told to start over and bleed the back brakes 1st starting on the right side. Then move to the front and start with the right side again. I did have someone pumping the brakes inside the car at the same time. I do want you guys to know I really appreciate the help. Thank alot.
Old May 5, 2009 | 06:27 AM
Huey52's Avatar
That's good advice, bleeding from longest to shortest run.
Glad you got it sorted, and enjoy your bask in the warm glow of self-accomplishment.
btw: down the road do get the speedbleeders; a really elegant solution.
Old May 5, 2009 | 05:30 PM
Hey Huey2,
What is a sppedbleeder and where can I get one? Thank for the advice.
Old May 5, 2009 | 08:42 PM
rx8cited's Avatar
Senior Member
...What is a sppedbleeder and where can I get one?...
This thread has your answers
Old May 6, 2009 | 06:16 AM
Huey52's Avatar
Got mine from Summit Racing. Don't forget to get the bag/tubing as well.
Edelbrock/Russell insight: http://www.russellperformance.com/mc/speed/import.shtml
Hey Huey2,
Old May 6, 2009 | 08:59 PM
I am definitely going to order them. Thanks again!!
crimson809
Aug 14, 2016 10:03 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
