electric help. headlights very dim.
hi, i have a 04 rx8 and last night as i started my car, my headlights went out, and my center console with my automatic shifter in it went out also.
i got out of my car and noticed my headlights are not out, just VERY dim. and taillights work fine, any ideas? i dont have warranty and mazda is expensive to send to. ty
i pushed down on all my fuses and checked em, they all are not burnt out, the headlight fuse or relay labeled HEAD is clean and secure, the car starts up fine so i dont think its alternator and i got a new battery less than a month ago. ( old one died) .
also is the headlights connected to the center console lights ? cuz those come off and on at random also.
So, it might be a lot of work. Following the circuit will eventually pinpoint the issue. Or, you could take a simpler but less accurate approach -- make sure battery connections are clean and tight, then replace the relay and see if problem goes away. If not then you're back to having to take a more disciplined troubleshooting approach.
Shankapotamus3
Mar 14, 2021 03:53 PM
GranTouTou
Sep 30, 2015 06:11 AM
drlubell
Sep 26, 2015 11:58 PM
