View Full Version : Autoweek 12/29 RX-8 Autofile
Zoom49
12-24-2003, 10:24 PM
"If this car doesn't elicit a grin, then I feel sorry for you "
Zoom49
12-24-2003, 10:30 PM
"RX-8 behaves as though directly linked to your cerebral cortex "
"Our RX-8 test log contains nary a negative comment "
Zoom49
12-24-2003, 10:41 PM
Great article likes, Rotary engine, Handling, brakes, better driving feel than 350Z - G35C
Dislikes Exterior styling??, Fuel mileage, low-end torque.
Said they recieved more passionate responses to this Autofile
than any in recient memory.
Zoom Zoom :) :) :D :D
downshift
12-24-2003, 10:43 PM
The pics are too small! If you can size it up a bit, that would be great! Thanks in advance!
compaddict
12-25-2003, 11:34 AM
Try:
http://www.autoweek.com/search/search_display.mv?port_code=autoweek&cat_code=autofile&content_code=08233204&Search_Type=STD&Search_ID=1773600&record=1
Vince
Zoom49
12-25-2003, 12:42 PM
Thanks for the help with the link Vince. I can upsize the scans but it is much easier to read, or print copy from the web.
Merry Christmas everyone !
Zoom49:)
revhappy
12-25-2003, 02:23 PM
Interesting article and the third in the last few weeks to comment negatively on the styling (it is obvious that the suicide doors and the related adjustments to the body are what this point is based on). The Fuel Economy they got was similar to some on this board - 15 MPG and they said the average of owners was 17 MPG, which is consistent with the poll taken here (are they stealing RX8forum material? p) The acceleration numbers look a bit unusual, 0-60 in 6.26 and the 1/4 mile in 14.75?:confused: Again, the slalom and skidpast test results were not that impressive, but the author definitely was impressed by the the balance and the driving dynamics of the RX8.
Broker73
12-25-2003, 03:04 PM
interesting article, however I noitced they have the skippad at .84g? That is the lowest I have seen it. C&D had it at .91g, and R&T .88g, a far cry from their estimates??
C&D at .91g had it above the G35?
I wonder why such a difference?
Hercules
12-26-2003, 02:57 PM
I wonder why such a difference? Could have been temperature... but who knows :\
Either way numbers don't put the smile on my face :)
Speed-ER doc
12-27-2003, 10:38 AM
Originally posted by Hercules
... numbers don't put the smile on my face :)
Once you get in, and the car wraps around you, and you experience all the driving pleasure you can get for 30K, who cares about the numbers.
JimW
01-07-2004, 12:00 PM
With these cars, it all depends on the driver, weather and track condition at the time of measurement!
racerdave
01-07-2004, 11:56 PM
Yeah, Jim said it. If they test on the same track after many tests and no rain, then the track (or pad) will be "run-in" and have a clean surface and some rubber laid down. These times and skidpad numbers will be good.
If they run on the same track after a rain or two, the surface will be "green" and the numbers will not be good for the intitial cars.
Unless it's the same day and done within about 10 minutes of one another, the stats are tough to rely on.
