View Full Version : CEL P0037 After RP cat install
renaldo
04-24-2009, 04:31 PM
Hi,
My stock cat failed a few weeks ago (p0420) so instead of replacing it with stock I got the RP High flow cat. I got that installed about 2 weeks ago and this morning I started my car and the CEL came on with P0037.
I researched this and it sounds like it is the rear o2 sensor? Any advice on this? Could this have been the problem all along or are the codes unrelated?
Razz1
04-24-2009, 04:34 PM
Re-set the ECU
renaldo
04-24-2009, 04:37 PM
Re-set the ECU
I cleared the code with an OBD2 reader and it came back after 2nd start. Clearing the ECU different?
Jedi54
04-24-2009, 04:38 PM
is the rear O2 sensor hooked up properly? wires on it are undamaged?
You "shouldn't" have a CEL from the supercat. What did your stock Cat look like when you took it off?
Razz1
04-24-2009, 04:39 PM
http://www.rx8club.com/showthread.php?t=171292
Sensor could have been broken during install.
renaldo
04-24-2009, 04:54 PM
We were very careful taking it off. I doubt that we damaged it. I guess it could just be a coincidence.
Razz1
04-24-2009, 05:10 PM
Make sure the exhaust doesn't have a leak.
No leaks, then for the fun of it clean the MAF, re-set ECU and see what happens.
teknics
04-24-2009, 07:26 PM
those sensors are fairly sensitive so "damaging" it doesnt require too much
kevin.
