Tire wear on rx8
Old Apr 18, 2009 | 05:24 PM
XXXrx8XXX's Avatar
Mazda Mica Grey 2006 GT
Tire wear on rx8
hey guys was just looking at my car and noticed that my back tire passenger side the middle is wearing off the little line in the center of the tire is gone compared to other tires...the car has 29000km on it and i always felt like the back tire made a weird noise like it wasnt aligned or so...
do our cars have an issue like the z
Old Apr 18, 2009 | 05:48 PM
cjkim's Avatar
^noob
umm.. get an alignment then?
what issue does the z have?
Old Apr 19, 2009 | 04:02 AM
rotarygreg's Avatar
grass hopper
if your tires are wearing speficically in the middle of the tread, you have too much air pressure in the affected tires (generally speaking) bad alignment will cause other types of wear, camber wear, shoulder wear, feathering etc.
Old Apr 19, 2009 | 09:33 AM
XXXrx8XXX's Avatar
well the tire is only on the back right side all other tires are fine as for the z i heard they had a cupping problem or something like that with the back tire
Old Apr 19, 2009 | 11:18 AM
rotarygreg's Avatar
grass hopper
well check your tire pressures man. If all your tires are set at the correct pressure and the tire in question is filled with like 45psi, then it will wear in the middle and the others wont. the correct tire pressure for the car is printed on a sticker on the drivers side "A pillar" / the leading edge of the back door near the bottom.
Old Apr 19, 2009 | 08:53 PM
nate340's Avatar
rx8's are a very tire friendly car, i rotate mine often ever 5000km or so. They tend to wear extremely even. seems that you need to rotate your tires immediately and should be paying closer attention to you tires for uneven wear your alignment could have been thrown out from hitting a pot hole or curb. i also find people tend to power slide/drift while turning left more often then right which would wear out your back right tire quicker than the others you'll be amazed how much wear occurs from sliding around with soft compound tires.
So to answer your question no the rx8 does not have a tire issue anything like the earlier z cars.
Old Apr 19, 2009 | 09:10 PM
01Racing's Avatar
Not that I know anything about tires..............lol real simple things to remember.
Tire worn in the center = over inflation
Tire worn evenly outer edges = under inflation
inner edges worn = excess toe out or too much negative camber
outer edges worn/cupped = excess toe in
These are basic tire wear rules. Accidents or other damage (hitting curbs holes etc) can cause other reasons for wear, but the above is a good basis to start.
Old Apr 19, 2009 | 09:38 PM
nate340's Avatar
**** i forgot that not everyone checks the tire pressure a few times a week. i just assumed someone would check their tire pressures before making an account and posting on a forum while assuming there car may have a serious problem before checking the simplest of things.
Old Apr 20, 2009 | 12:24 PM
01Racing's Avatar
ZING...................Ouch that hurts (lol)
Old Apr 20, 2009 | 12:51 PM
Kafka's Avatar
I've once read on the internet that you don't need to check tire pressure since it will refill itself...
Old Apr 20, 2009 | 04:31 PM
ZmFnZm's Avatar
Ah you mean those special magic tires!! I think i have a set somewhere..... LOL
Old Apr 20, 2009 | 04:40 PM
rotarygreg's Avatar
grass hopper
ya, those ones that have perfect winter and summer taction, racetrack or ice rink. and they last 100 000km. i think firestone makes them. lol
Old Apr 20, 2009 | 07:20 PM
ZmFnZm's Avatar
Yeah Greg those are the ones!!!
Duren1
Mountain For Sale/Wanted
Jan 11, 2017 09:07 AM
BigMikeATL
May 26, 2016 12:31 AM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
cschoeps
Aug 6, 2015 12:44 PM
