How do you remove the battery tray?
Old Apr 11, 2009 | 03:13 PM
JantzenRX-8's Avatar
I plan on relocating my battery at some point so I figured i'd give it a shot while I have my intake removed. I can't figure out how to remove the battery tray. There is only one bolt that is visible and/or obvious that I've removed and there is something else holding it in on the left hand side.
Anyone have any experiences with this? It's rather frustrating because i feel like this should be an easy task.
Old Apr 11, 2009 | 03:33 PM
there is 2 bolts to the left, covered by the big black plastic tube thing.
Lift it up a bit, u will see 2 bolts. use a 10mm head to take it off.
Old Apr 11, 2009 | 05:14 PM
hmm, i remember seeing one of them but it was covered by the J-hook that held the hose in place. It seemed impossible to get to as is.
Old Apr 11, 2009 | 05:33 PM
rx8cited's Avatar
Senior Member
See this DIY which includes pictures of the left side bolts
Old Apr 11, 2009 | 05:43 PM
Nicely done.
Thank you.
Old Apr 11, 2009 | 06:29 PM
rx8cited's Avatar
Senior Member
Originally Posted by JantzenRX-8
Nicely done.
Thank you.
No problem. BTW, forgot to mention, it's a good time to check the electrolyte level while you're in there, if your battery is like my stock battery and has removable caps. Add distilled water, if necessary. And be careful to not drop any nuts in.
92trbolzr
May 18, 2025 09:04 AM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
