Does anyones engine coolant light come on when they race thier engine
Old Apr 10, 2009 | 08:03 PM
justintime's Avatar
My coolant light comes even though it's full, but only when I race my engine
Old Apr 10, 2009 | 08:15 PM
StealthTL's Avatar
Metatron
A bad sensor can indicate a false low level.
Try topping right up with coolant, or get it 'dealered'.
Mine shows low at 90 mph, no matter how full it is.....
Old Apr 11, 2009 | 07:51 AM
japlaza787's Avatar
Keep an eye. Although I don't race, mine began to appear at high speeds, then did it no matter how fast or slow you drive. My 8 is 2004. In my case, and I have seen the same in other posts, I ended up changing the coolant reservoir. It has a sensor inside, at one of its side, that there is no chance to change it so you have to change the reservoir. Should be between $150 to $200. If DIY, watch out with a short hose the reservoir has at the back (called the overflow hose) since it is very easy to brake its conection to the plastic radiator cover.
Old May 4, 2009 | 05:36 PM
katiewagg's Avatar
yeah at higher speeds or racing my light comes on, but usually turns off within 5 or 10 seconds...in the manual i think it says that if the light stays on then to immediatly pull over, let your car cool down.
Old May 4, 2009 | 07:37 PM
yale02's Avatar
Still plays with cars
under heavy throttle mine has just started coming on... half a minute to a few minutes and then goes out. Coolant level checked and fine. I think it is a bad sensor as mentioned above and will have to go to the dealer.
Old May 4, 2009 | 07:45 PM
Once or twice:
Only when I go too fast around corners. The fluid has a tendency to force its way out.
One time I was missing the resovouir nut. Check the botle make sure it is tight.
Old May 4, 2009 | 08:38 PM
rx8cited's Avatar
Senior Member
Coolant level should be checked with cold engine. Level should be near reservoir "F" line.
Old May 5, 2009 | 07:48 AM
lorryload's Avatar
top up solved this for me - was coming on at high cruising speeds (80MPH plus)
Old May 5, 2009 | 11:08 AM
Socket7's Avatar
ಠ_ಠ
yup. Comes on when I'm doing my sunday drives all the time. I get it up above 4K for a length of time and the light comes on until i shift into neutral and let the revs drop to 2K for a few seconds. Gotta send it in for warranty work to fix that.
Old May 5, 2009 | 11:15 AM
onyx8's Avatar
What do you all top off with?
Old May 5, 2009 | 12:14 PM
Socket7's Avatar
ಠ_ಠ
I go to the dealership and they top me up with FL-22 no charge.
Owners manual says don't use anything else.
vapor2
Nov 3, 2020 03:38 PM
MarkX
Jul 31, 2015 07:50 AM
Stubbs
Jul 28, 2015 09:23 PM
dmac1961
Jul 24, 2015 11:27 AM
AussieGray
Jul 16, 2015 03:58 AM
