SPEC Clutch and Flywheel??
Old Apr 8, 2009 | 09:24 PM
Nitrous88's Avatar
Question SPEC Clutch and Flywheel??
does anyone have the stage 3+ clutch kit and aluminum lightweight flywheel from SPEC???
hows it working and has anyonw had anyproblems ?
iv looked around and jsut havent found the info im looking for on here.
Old Apr 8, 2009 | 10:19 PM
Jon316G's Avatar
Grasshopper
Just curious why you feel the need to go up to a stage 3.
And do you use your 8 as a daily driver?
Old Apr 8, 2009 | 10:46 PM
Flashwing's Avatar
3-wheeler
BHR sells a direct line of SPEC clutches as well as our lightweight flywheel which is also made by SPEC.
As JohnG asked, is their a particular reason you feel you need a stage3+?
Old Apr 8, 2009 | 10:57 PM
stage 3?! whoa.
is this pretty much a track car?
Old Apr 8, 2009 | 11:33 PM
teknics's Avatar
Certified Mazda Tech
spec clutches have been good to me on rotaries, i use their unsprung puck clutches.
kevin.
Old Apr 9, 2009 | 11:45 AM
Charles R. Hill's Avatar
Owner of BHR
The SPEC Stage 1 clutch will handle 300 lb./ft. of torque. WAY more than an N/A (and most F/I'd) Renesis is going to make. Not only does BHR have the SPEC flywheels, I have SPEC "specially" modify them and my price ends up being cheaper than the SPEC unit.
BHR also has a lightweight pressure plate in the clutch kit that weighs almost 4 lbs. less than other pressure plates but I want to do another round of testing before I re-release them to the market.
Old Apr 9, 2009 | 03:17 PM
kersh4w's Avatar
Hit & Run Magnet
never use clutches that are over-rated for your car. a tough clutch will easily kill your joy of driving.
farfegnugen baby!
Old Jun 25, 2009 | 07:46 PM
cooldriver88's Avatar
does the SPEC flywheel need a counter weight? or does it come with one?
Old Jun 25, 2009 | 08:54 PM
RyansRx8's Avatar
Brettward is/has a G
Stage1 is plenty!!!!!!!!! for daily drivers
Old Jun 25, 2009 | 09:03 PM
Jon316G's Avatar
Grasshopper
You need a counter weight with it.
I got the ACT counter weight with my SPEC flywheel.
Old Jun 25, 2009 | 09:19 PM
Mawnee's Avatar
I divide by zero
I will say this about buying a stonger clutch than you need. It would have saved me a fortune to do so with my vette. I repeatedly upgraded other parts and proceeded to exceed the limits of the whichever clutch I had installed. I went through 5 clutches before settling on the spec 3+. Thing was supposed to hold 850ft/lbs but felt and engaged like stock
If I could do it all over...I would buy that clutch first and save myself a couple grand
theblinkof
Oct 4, 2023 05:24 PM
Quiggs321
Sep 30, 2015 05:34 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
