Caliper Bolt Problem
Old Apr 8, 2009 | 08:25 PM
vtfanatic69's Avatar
So tonight I began my attempt at painting my brake calipers and the inner part of my rotor. I also just wanted to tidy up my wheels and such. Well I went to the rear caliper to remove it, and found one of the bolts is partially stripped. It was also incredibly stubborn. I tried to remove the bolt with the socket wrench, but it just would not budge. Is my only option to take it to a shop and have them loosen the bolts with an impact wrench? Also if they cannot remove it how do I get the bolt off?
Old Apr 8, 2009 | 08:46 PM
G3tR3DDY2GR3DDY's Avatar
you dont have enough strength to break the caliper bolt so you think its a good idea to take it to a shop and pay to have it broken loose?
why dont you think about it for a second, go to autozone and buy a real tool, then go back and accomplish the task. then pretend you didnt admit to being a wuss .. jk :P kinda..
Old Apr 8, 2009 | 08:51 PM
Ok, a little harsh, but thanks for the reply. Being 17 money is kind of an object, but do you think it will be more expensive to take it to a shop than buy the tool myself? I will buy it if so, but I want to make sure it's the most logical thing to do.
Old Apr 8, 2009 | 08:52 PM
StealthTL's Avatar
Metatron
....and don't forget, that because the bolt is on the inboard side of the caliper, lefty-loosey becomes RIGHTY-loosey!!
Old Apr 8, 2009 | 08:57 PM
lol a shop is gonna try to pull some diagnostic **** on you and you should have proper tools .
being 17 is not an excuse, if you are gonna own an expensive sports car you need to throw that line out the window.
Old Apr 8, 2009 | 08:59 PM
Ya thanks for the directions on loosening lol. I had to think about it for a second when I first started. I guess if I can't get the bolt off I'll go hit up the local autozone tomorrow. Thanks for the replies.
Old Apr 8, 2009 | 09:11 PM
kersh4w's Avatar
Hit & Run Magnet
if you dont know,
this is the proper tool. its called a breaker bar. use it, and it wont be a problem, especially when remembering its righty loosey because its facing away from you.
Old Apr 8, 2009 | 09:40 PM
I have never seen that, but judging by the name, it's the right toll for me. They should sell that at autozone right?
Also I was able to get the front calipers loose so those are ready for painting in the morning.
Old Apr 8, 2009 | 10:18 PM
Jon316G's Avatar
Grasshopper
I've had to use a breaker bar before on the caliper bolt.
But don't go out and get the longest breaker bar you can find (I think Autozone has a 24" length bar).
Remember that you need to use it in the wheel well, so take that into consideration.
Old Apr 9, 2009 | 09:40 AM
EDZRIDE's Avatar
2005 White GT
Check Sears too.
Old Apr 9, 2009 | 09:47 AM
Huey52's Avatar
Registered Zoom Zoomer
Yes, the 'zone typically stocks 18" and 24" breaker bars. 18" is plenty (and if it isn't, time for the gym).
I had to recently use a breaker on the upper differential fluid nut. It happens.
Old Apr 9, 2009 | 10:26 AM
I picked up the 18" one and it worked like a charm. Calipers are coming along fine now, thanks everyone.
Old Apr 9, 2009 | 11:56 AM
WHAT!
You didn't buy a new bolt first?
Don't put that old one back in there.
Old Apr 9, 2009 | 11:58 AM
Here's an update of the first one done
Old Apr 9, 2009 | 03:12 PM
kersh4w's Avatar
Hit & Run Magnet
looks good. did you fully take it off, disconnect the brake fluid line and all that?
where are you located?
i've reused the bolt before, why is that bad razz?
Old Apr 9, 2009 | 04:38 PM
Huey52's Avatar
Hey, looks just like mine. Nice.
Old Apr 9, 2009 | 04:46 PM
I just slid it off the rotor, then masked off everything that could get hit by overspray. I used a steel brush on a drill to get all the brake dust off, the used a brake cleaner to get any residue. Then I did three coats.
I also wonder why I can't use the same bolt. Please explain
Also, I am having enormous trouble putting the caliper on the rotor for my second wheel. I know people say use a c lock to compress the brake piston, but I have no idea how to do this. Can anyone help?
Old Apr 9, 2009 | 06:25 PM
You said the bolt was stripped.
Old Apr 9, 2009 | 06:49 PM
Oh yes I swapped it out. The guy I bought my car from had parts lying around and he had a replacement of the right size. I was worried for a second you meant all the unscrewed bolts were unstable.
Old Apr 9, 2009 | 06:55 PM
Jon316G's Avatar
Grasshopper
I use a C-clamp to compress the piston back.
This will only work for the front caliper, don't try it on the rears!!!
And make sure you remove the cap on the brake fluid reservoir before compressing the piston.
This will allow the fluid to be pushed back into the reservoir.
So you might want to have a rag handy in case the fluid pours out from the top.
But if you didn't change the brake pads, then you shouldn't need to compress the piston that much.
Old Apr 9, 2009 | 07:01 PM
Ya my dad says he knows the c clamp way to do it. I'll let him do it then. Ya for the rears i'll either have to find the tool or get a little more creative.
Old Apr 9, 2009 | 07:04 PM
Jon316G's Avatar
Grasshopper
Then your dad probably knows how to use needle nose pliers on the rears.
My dad was pretty "old school" too.
Old Apr 9, 2009 | 07:07 PM
Haha I asked him and he does indeed.
Old Apr 10, 2009 | 06:52 AM
Huey52's Avatar
Autozone also has a universal tool for compressing the pistons. It's basically a "socket cube" with pins on all sides to mate with a variety of brakes.
Old Apr 10, 2009 | 10:36 AM
Does this tool you mentioned work with the rear calipers as well?
