ignition coil order
Old Apr 8, 2009 | 01:56 PM
rx81980's Avatar
NH ignition coil order
If you are looking down at the ignition coils from thr drivers side wheel, what is the order from left to right of the coils?
Old Apr 8, 2009 | 03:03 PM
invasion08's Avatar
Leading 1, trailing 1, leading 2, trailing 2
Old Apr 8, 2009 | 03:31 PM
tsxmidship's Avatar
courtesy of http://www.myrotarycar.com/portal/fo...3le/index.html
Old Apr 8, 2009 | 05:01 PM
teknics's Avatar
Certified Mazda Tech
^ nice image
kevin.
Old Apr 9, 2009 | 11:47 AM
Charles R. Hill's Avatar
Owner of BHR
It is also stamped on the factory coil bracket/baseplate.
Old Dec 3, 2009 | 03:39 AM
g0rdhan's Avatar
what you mean? i cant seem to find where it says that.. i got some extra coils on the base it says 1 - 1 or 1 - 3 or 1 - 4 or 1 - 1... (those are what the ones i have say on them)
any ideas anyone??
i know that manual was posted, but its a little hard to see the picture
Old Dec 3, 2009 | 07:51 AM
Huey52's Avatar
Registered Zoom Zoomer
^ The coils themselves are interchangeable. It's the firing order (input sockets and output cables) that must be properly sequenced.
Ray was referring to the coil bracket itself which is stamped with the firing order.
The engine block has similar cast labeling for the 'plugs.
Again, the coil firing order from front to rear of engine bay: leading 1, trailing 1, leading 2, trailing 2
05TR1CH
Apr 18, 2023 04:56 AM
rotorocks
47
May 11, 2016 03:23 PM
talonhart2
Aug 26, 2015 04:14 PM
MolecularConcept
Aug 5, 2015 04:43 PM
madrotor
Jul 26, 2015 12:06 PM
