intake problems
Old Apr 8, 2009 | 01:15 PM
greddy617dc's Avatar
intake problems
when i put my arc intake in my car it ran fine for about a month after that the check engine light came on the rpms revved like crazy and the car kept stalling out whenever i came to a stop light. it reads system to lean. than i put the stock air filter back in and it was fine. do i need dyno tuning?
thanks, danny
Old Apr 8, 2009 | 02:56 PM
Failed ?
Search ?
Old Apr 8, 2009 | 03:15 PM
Shnifty's Avatar
Is Nifty
Sounds like you hooked something up wrong... What type of intake?
Old Apr 8, 2009 | 03:25 PM
636's Avatar
636
Rice Police
Probably have a leak.
Old Apr 8, 2009 | 03:45 PM
droob's Avatar
Could be a leaky vacuum line. Check that all 3 are hooked up properly.
Did you disconnect the battery at some point? If so that will reset the map back to factory. You will need to drive around for a bit so that the car can "re-learn" how to manage the air intake.
Old Apr 8, 2009 | 03:49 PM
J03K1LLARX8's Avatar
ジョーイ
reset the ecu.
Old Apr 8, 2009 | 05:17 PM
Shijin-Kun's Avatar
Rotary Power!
what cel was it giving you?
Old Apr 8, 2009 | 07:21 PM
i got an arc intake its not a vacuum hose and it reads system to lean when i out the stock in its fine would i need to tune it?
thanks
Old Apr 9, 2009 | 11:16 AM
an arc intake http://www.directtuning.com/store/im...arge/57235.jpg
RevMeHarder
Jun 1, 2026 02:30 PM
ed0128
Sep 9, 2015 04:50 PM
Kim Jong Illest
Sep 4, 2015 04:27 PM
Octomus
Sep 3, 2015 11:40 AM
